Straightforward replacement of a power chord.
Disassembly of an iron can sometimes be tricky; this one has one hidden screw.
Philips Comfort 215 Iron:
Remove the two phillips screws at the back.
Remove the turning knob to reveal the third screw. The knob can be lifted once it is in the right orientation; it needs very little force.
The top cover can now be removed
The connectors are held in place by a peg; release them by pushing a small lever in the middle of the connector.
Here the old connectors have been soldered to the new wire; the joint has been covered with heat-shrink tubing.
As always, take care that the wire is routed correctly through the top cover and entry guide before connecting everything
