Petcube Play 2 Speaker Replacement
  1. Petcube Play 2 Speaker Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement, Motherboard: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip over the Petcube so the rubber bottom faces you.
    • Pull up the rubber layer with an iFixit opening pick to expose the screws underneath.
  2. Petcube Play 2 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 3.5mm screws from under the rubber cover with a Phillips #1 screwdriver.
    • The glue may cause a bit of resistance but the screws should come up without much effort.
  3. Petcube Play 2 Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pry off the glass front panel with an opening pick or spudger.
    • Do not force the front panel off as it may crack and break.
  4. Petcube Play 2 Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide off the two covers, starting with the top plastic cover.
    • Slide out the internal assembly from the aluminum.
  5. Petcube Play 2 Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the internal assembly is removed, a brass cylinder in a corner of the front face of the cube should be visible. Connected to the cylinder is a screw.
    • Remove the screw with a Phillips #1 screwdriver.
  6. Petcube Play 2 Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the cube onto its side to locate the pull tab(s).
    • Flip the cube onto its side to locate the pull tab(s). Using an opening tool, lift each of the five tabs to separate the two halves of the Petcube 2.
  7. Petcube Play 2 Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently disconnect the cable connectors to separate the two halves of the device.
    • Make sure to avoid pulling on the wires to prevent breaking them or the connectors.
  8. Petcube Play 2 Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Phillips #1 screwdriver to remove the two 1mm screws.
    • Carefully release each of the tabs located on the sides of the cube and take out the motherboard.
    • Be gentle with the tabs as they will break under too much pressure.
  9. Petcube Play 2 Speaker Replacement, Speaker: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement, Speaker: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement, Speaker: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take the half of the device that doesn't contain the motherboard and place it down so that the top screws are visible.
    • Use a Phillips #1 screwdriver to remove the seven screws.
  10. Petcube Play 2 Speaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to remove the wire connector attaching the two halves together.
    • Separate the two halves and isolate the one containing the speaker.
  11. Petcube Play 2 Speaker Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the other half of the cube, remove the four screws using a Phillips #1 screwdriver.
  12. Petcube Play 2 Speaker Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the flat bottom and the cover of the speaker and gently pull them apart to separate to expose the speaker.
    • Be careful when pulling the two apart to avoid damaging the other internal parts as they are connected by the speaker cable.
  13. Petcube Play 2 Speaker Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the two screws securing the speaker.
    • Use a soldering iron to desolder the wires connecting the speaker to the device.
    • Make sure to follow safety protocols with soldering and take your time as to prevent injury.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Jim Clifton
crwdns2935283:003/18/24crwdne2935283:0
121 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-5, Konn Spring 2024 crwdns2935289:0UMass Dartmouth, Team 1-5, Konn Spring 2024crwdne2935289:0
UMASSD-KONN-S24S1G5
crwdns2942667:0crwdne2942667:0 135
