Petcube Play 2 Speaker Replacement
  1. Petcube Play 2 Speaker Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement, Motherboard: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip over the Petcube so the rubber bottom faces you.
    • Pull up the rubber layer with an iFixit opening pick to expose the screws underneath.
  2. Petcube Play 2 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 3.5mm screws from under the rubber cover using a Phillips #1 screwdriver.
    • The glue may cause slight resistance, but the screws should come out with minimal effort.
  3. Petcube Play 2 Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pry off the glass front panel using an opening pick or a spudger.
    • Do not force the front panel off, as it may crack and break.
  4. Petcube Play 2 Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide off the two covers, starting with the top plastic cover.
    • Slide out the internal assembly from the aluminum casing.
  5. Petcube Play 2 Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the internal assembly is removed, a brass cylinder in one corner of the cube's front face will be visible. A screw will be attached to it.
    • Remove the screw with a Phillips #1 screwdriver.
  6. Petcube Play 2 Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the cube onto its side to locate the pull tabs.
    • Using an opening tool, lift each of the five tabs to separate the two halves of the Petcube 2.
  7. Petcube Play 2 Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently disconnect the cable connectors to separate the two halves of the device.
    • Avoid pulling on the wires to prevent damage to the connectors.
  8. Petcube Play 2 Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the two 1mm screws.
    • Carefully release each of the tabs on the sides of the cube and remove the motherboard.
    • Be gentle with the tabs. They will break under too much pressure.
  9. Petcube Play 2 Speaker Replacement, Speaker: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement, Speaker: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement, Speaker: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take the half of the device that doesn't contain the motherboard and place it down so that the top screws are visible.
    • Use a Phillips #1 screwdriver to remove the seven screws.
  10. Petcube Play 2 Speaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to remove the wire connector attaching the two halves together.
    • Make sure to avoid pulling on the wires to prevent breaking them or the connectors.
    • Separate the two halves and isolate the one containing the speaker.
  11. Petcube Play 2 Speaker Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the other half of the cube, remove the four screws using a Phillips #1 screwdriver.
  12. Petcube Play 2 Speaker Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the flat bottom and the cover of the speaker and gently pull them apart to separate to expose the speaker.
    • Be careful when pulling the two apart to avoid damaging the other internal parts as they are connected by the speaker cable.
  13. Petcube Play 2 Speaker Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Speaker Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the two screws securing the speaker.
    • Use a soldering iron to desolder the wires connecting the speaker to the device.
    • Make sure to follow safety protocols with soldering and take your time as to prevent injury.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Jim Clifton
crwdns2935283:003/18/24crwdne2935283:0
121 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-5, Konn Spring 2024 crwdns2935289:0UMass Dartmouth, Team 1-5, Konn Spring 2024crwdne2935289:0
UMASSD-KONN-S24S1G5
crwdns2942667:0crwdne2942667:0 153
