Petcube Play 2 Motherboard Replacement
  1. Petcube Play 2 Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip over the Petcube so the rubber bottom faces you.
    • Pull up the rubber layer with an iFixit opening pick to expose the screws underneath.
  2. Petcube Play 2 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Petcube Play 2 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 3.5mm screws from under the rubber cover with a Phillips #1 screwdriver.
    • The glue may cause a bit of resistance but the screws should come up without much effort.
  3. Petcube Play 2 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Petcube Play 2 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pry off the glass front panel with an opening pick or spudger.
    • Do not force the front panel off as it may crack and break.
  4. Petcube Play 2 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide off the two covers, starting with the top plastic cover.
    • Slide out the internal assembly from the aluminum.
  5. Petcube Play 2 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Motherboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the internal assembly is removed, a brass cylinder in a corner of the front face of the cube should be visible. Connected to the cylinder is a screw.
    • Remove the screw with a Phillips #1 screwdriver.
  6. Petcube Play 2 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Motherboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the cube onto its side to locate the pull tab(s).
    • Flip the cube onto its side to locate the pull tab(s). Using an opening tool, lift each of the five tabs to separate the two halves of the Petcube 2.
  7. Petcube Play 2 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently disconnect the cable connectors to separate the two halves of the device.
    • Make sure to avoid pulling on the wires to prevent breaking them or the connectors.
  8. Petcube Play 2 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Petcube Play 2 Motherboard Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Phillips #1 screwdriver to remove the two 1mm screws.
    • Carefully release each of the tabs located on the sides of the cube and take out the motherboard.
    • Be gentle with the tabs as they will break under too much pressure.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Jacob Branco
crwdns2935283:003/18/24crwdne2935283:0
291 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-5, Konn Spring 2024 crwdns2935289:0UMass Dartmouth, Team 1-5, Konn Spring 2024crwdne2935289:0
UMASSD-KONN-S24S1G5
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 145
