If the laser toy of your Petcube Play 2 (identified by model number PP2OUS) is malfunctioning, use this guide to replace it.
The Petcube Play 2 comes with a controllable laser toy usable from the Petcube app. Repeated use or a defective laser might lead to the laser malfunctioning or not turning on.
Before using this guide, ensure that there are no connection issues between the Petcube, your Wi-Fi router, and your phone. The Troubleshooting Page covers connection related issues and how to address them.
Ensure the Petcube Play 2 is turned off before beginning the replacement process.
Flip over the Petcube so the rubber bottom faces you.
Pull up the rubber layer with an iFixit opening pick to expose the screws underneath.
Remove the four 3.5mm screws from under the rubber cover using a Phillips #1 screwdriver.
Carefully pry off the glass front panel using an opening pick or a spudger.
Slide off the two covers, starting with the top plastic cover.
Slide out the internal assembly from the aluminum casing.
Remove the screw with a Phillips #1 screwdriver.
Flip the cube onto its side to locate the pull tabs.
Using an opening tool, lift each of the five tabs to separate the two halves of the Petcube 2.
Gently disconnect the cable connectors to separate the two halves of the device.
Use a Phillips #1 screwdriver to remove the two 1mm screws.
Carefully release each of the tabs on the sides of the cube and remove the motherboard.
Use a Phillips #1 screwdriver to remove the seven screws from the part of the cube where the motherboard was removed.
Remove the plastic front to expose the board with the laser.
Once the motherboard is off and the plastic is removed, the internal circuit board is visible.
Remove the board from the plastic and locate the lasers ribbon connector.
Use a spudger, or a clean fingernail to flip up the locking flap—this is the unlocked position.
Use tweezers or your fingers to gently pull the cable out of its socket and remove the laser assembly from the board.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
