crwdns2959928:0crwdne2959928:0 ↓If the camera of your Petcube Play 2 (identified by model number PP2OUS) is malfunctioning, use this guide to replace it.
The Petcube Play 2 comes with a built-in camera that can record and stream videos of your pet to your phone. A defective camera might lead to poor video quality, skipping, or recording failures.
Before using this guide, ensure that there are no connection issues between the Petcube, your Wi-Fi router, and your phone. The Troubleshooting Page covers connection and video quality-related issues and how to address them.
Ensure the Petcube Play 2 is turned off before beginning the replacement process.
Spudger4.9
Flip over the Petcube so the rubber bottom faces you.
Pull up the rubber layer with an iFixit opening pick to expose the screws underneath.
Remove the four 3.5mm screws from under the rubber cover using a Phillips #1 screwdriver.
Carefully pry off the glass front panel using an opening pick or a spudger.
Slide off the two covers, starting with the top plastic cover.
Slide out the internal assembly from the aluminum casing.
Remove the screw with a Phillips #1 screwdriver.
Flip the cube onto its side to locate the pull tabs.
Using an opening tool, lift each of the five tabs to separate the two halves of the Petcube 2.
Gently disconnect the cable connectors to separate the two halves of the device.
Use a Phillips #1 screwdriver to remove the two 1mm screws.
Carefully release each of the tabs on the sides of the cube and remove the motherboard.
Use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
Use the Phillips #00 screwdriver to remove the three 1 mm screws securing the camera to the motherboard.
Remove the camera from the motherboard.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
