Pentax Optio WG-3 GPS Screen Replacement
crwdns2944105:0crwdne2944105:0
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using a Philips screwdriver (PH00), remove the 6, 5 mm screws, 4 on each corner and 2 on the sides of the device.
With the small plastic pry tool lift the back of the camera off carefully.
Remove the 4, 2 mm screws from each corner of the metal screen cover.
Detach flex cable and replace screen component.
Any idea where you can buy the replacement screen from? I’m not having any luck finding one. Thank you!
