   crwdns2935267:0crwdne2935267:0Tweezers$4.99-
            Using a Philips head screwdriver, remove the 6, 5 mm screws, 4 on each corner and 2 on the sides of the device.
            With the small plastic pry tool lift the back of the camera off carefully.
            Remove the 6, 2 mm screws from each corner of the metal button pad cover.
            Using tweezers remove the metal cover.
            Disconnect the flex cables and replace the menu pad button or button component.
                                    crwdns2935219:0crwdne2935219:0
