Pentax Optio WG-2 LCD Screen Replacement
crwdns2942287:0crwdne2942287:0Use this guide to replace the LCD viewing screen on the back of the Pentax Optio WG-2.
crwdns2944105:0crwdne2944105:0
crwdns2931653:01crwdne2931653:0 Back Case
crwdns2944590:01crwdnd2944590:06crwdnd2944590:0crwdnd2944590:0crwdne2944590:0
Remove all four 1 mm JIS #00 screws from the back of the camera.
Use your finger to peel the grip off the top of the camera.
For best results, start from the right side of the camera, opposite the buttons.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use the tweezers to remove the two buttons from the top of the camera.
Remove the three 1 mm JIS #000 screws from the top.
Remove the 1 mm JIS #000 screw from the bottom.
Carefully separate the back and the front of the camera.
Use the tip of a spudger to flip up the small retaining flaps on the ribbon cable ZIF connectors.
Carefully pull the ribbon cables out of their sockets.
Carefully remove the clear tape covering the screws and the ribbon cable.
We want to remove the larger silver panel (right). The best way to do this is to slightly bend the cover backwards and use the tweezers to grab a corner and slowly lift the screen up and out.
Once the screen is removed you should have two pieces as seen in the picture.
The screen is the silver rectangle in the top of the picture or the component seen in picture two.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:02crwdne2947412:0
Dónde puedo comprar el Display?
Where I can buy the dispaly?
opération réussie ça marche nickel la plus grosse difficultée est de remettre correctement les 3 connecteurs
impératif: utiliser les bons outils comme indiqué attention aux vis il y a un petit joint et les longueurs différentes ne pas mélanger !!!
merci pour ce super tuto ….
