Pentax Optio WG-2 Back Case Replacement
crwdns2862623:0crwdne2862623:0
crwdns2948751:0crwdne2948751:0
    1. Pentax Optio WG-2 Back Case Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax Optio WG-2 Back Case Replacement, Back Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove all four 1 mm JIS #00 screws from the back of the camera.
    2. Pentax Optio WG-2 Back Case Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your finger to peel the grip off the top of the camera.
      • For best results, start from the right side of the camera, opposite the buttons.
      • Once the grip is removed, you will most likely lose the water-tight seal.
    3. Pentax Optio WG-2 Back Case Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the tweezers to remove the two buttons from the top of the camera.
      • The buttons may fall out while removing the grip.
    4. Pentax Optio WG-2 Back Case Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pentax Optio WG-2 Back Case Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pentax Optio WG-2 Back Case Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the three 1 mm JIS #000 screws from the top.
      • Remove the 1 mm JIS #000 screw from the bottom.
    5. Pentax Optio WG-2 Back Case Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully separate the back and the front of the camera.
      • There are three ribbon cables connecting the two boards. Be careful not to tear them.
    6. Pentax Optio WG-2 Back Case Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the tip of a spudger to flip up the small retaining flaps on the ribbon cable ZIF connectors.
      • Carefully pull the ribbon cables out of their sockets.
Matthew Bessette
crwdns2935283:003/04/16crwdne2935283:0
658 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 6-7, Bhusal Spring 2016 crwdns2935289:0UMass Dartmouth, Team 6-7, Bhusal Spring 2016crwdne2935289:0
UMASSD-BHUSAL-S16S6G7
crwdns2942667:0crwdne2942667:0 290
