Pentax Optio WG-2 LCD Screen Replacement
    1. crwdns2944590:01crwdnd2944590:06crwdnd2944590:0crwdnd2944590:0crwdne2944590:0
      Pentax Optio WG-2 LCD Screen Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax Optio WG-2 LCD Screen Replacement, Back Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove all four 1 mm JIS #00 screws from the back of the camera.
    2. Pentax Optio WG-2 LCD Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your finger to peel the grip off the top of the camera.
      • For best results, start from the right side of the camera, opposite the buttons.
      • Once the grip is removed, you will most likely lose the water-tight seal.
    3. Pentax Optio WG-2 LCD Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the tweezers to remove the two buttons from the top of the camera.
      • The buttons may fall out while removing the grip.
    4. Pentax Optio WG-2 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pentax Optio WG-2 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pentax Optio WG-2 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the three 1 mm JIS #000 screws from the top.
      • Remove the 1 mm JIS #000 screw from the bottom.
    5. Pentax Optio WG-2 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully separate the back and the front of the camera.
      • There are three ribbon cables connecting the two boards. Be careful not to tear them.
    6. Pentax Optio WG-2 LCD Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the tip of a spudger to flip up the small retaining flaps on the ribbon cable ZIF connectors.
      • Carefully pull the ribbon cables out of their sockets.
    1. Pentax Optio WG-2 LCD Screen Replacement, LCD Screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax Optio WG-2 LCD Screen Replacement, LCD Screen: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully remove the clear tape covering the screws and the ribbon cable.
      • Be careful not to tear the ribbon cable when removing the tape.
      • We want to remove the larger silver panel (right). The best way to do this is to slightly bend the cover backwards and use the tweezers to grab a corner and slowly lift the screen up and out.
    2. Pentax Optio WG-2 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax Optio WG-2 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Once the screen is removed you should have two pieces as seen in the picture.
      • The screen is the silver rectangle in the top of the picture or the component seen in picture two.
Matthew Bessette
crwdns2935283:003/04/16crwdne2935283:0
658 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 6-7, Bhusal Spring 2016 crwdns2935289:0UMass Dartmouth, Team 6-7, Bhusal Spring 2016crwdne2935289:0
UMASSD-BHUSAL-S16S6G7
Dónde puedo comprar el Display?
Where I can buy the dispaly?
Sebastian Mesa - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
opération réussie ça marche nickel la plus grosse difficultée est de remettre correctement les 3 connecteurs
impératif: utiliser les bons outils comme indiqué attention aux vis il y a un petit joint et les longueurs différentes ne pas mélanger !!!
merci pour ce super tuto ….
walchkorn - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 1,372
