Pebble Time Screen Replacement
  1. Pebble Time Screen Replacement, Screen Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the watch flat on your workstation.
  2. Pebble Time Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pebble Time Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the metal spudger to carefully pull apart the screen cover from the case.
    • Replace the metal spudger with a plastic opening tool to hold the cover open.
    Just a note whilst removing the cover/screen - on my Pebble Time Steel, the LCD seemed to actually be attached to the glass, so when the adhesive around the outside seperated, I disconnected the ribbon cable and removed both as one piece - if you can, this definitely helps keep the end result a bit tidier!
    Aadi Bhamidipati - crwdns2934203:0crwdne2934203:0
  3. Pebble Time Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the metal spudger tool to carefully loosen the rest of the cover.
  4. Pebble Time Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully, pull apart the cover with the plastic opening tool.
  5. Pebble Time Screen Replacement, Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert metal spudger into the side of the screen shown in the picture.
  6. Pebble Time Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the metal spudger to pry the screen up.
  7. Pebble Time Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pebble Time Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pebble Time Screen Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
    • Disconnect the screen from the circuit board.
    There might be some yellow / brown sticky tape that covers the lower end of the ribbon cable and those 6 shiny contact pads. You can carefully pull it off when you lift up the cable.
    Henrik L - crwdns2934203:0crwdne2934203:0
Saud Al-Malki
crwdns2935283:002/19/17crwdne2935283:0
110 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-3, Sullivan Spring 2017 crwdns2935289:0USF Tampa, Team 1-3, Sullivan Spring 2017crwdne2935289:0
USFT-SULLIVAN-S17S1G3
Where can I buy the display replacement?
ulises - crwdns2934203:0crwdne2934203:0
Hello Ulises,
Based off of my search, I couldn’t find any place where you can buy a display replacement. I advise you to look on Ebay, Amazon, or you can contact Pebble Time for more information at https://www.pebble.com or +18882245820. If none of this works out for you, you might want to check local tech repair shops.
Hope this helps.
Saud Al-Malki - crwdns2934203:0crwdne2934203:0
Hola.
¿I have a question ?
What adhesive What adhesive should I buy to stick it again after placing the screen?
bladimir gonzalez matos - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 61
crwdns2942667:0crwdne2942667:0 3,404
