This guide will walk you through steps to replace your joystick.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
Four 0.9mm T6 screws
Two 0.1mm T6 screws
Flip the Flypad over.
Remove the six screws using a T6 screwdriver.
Flip the Flypad over again and separate the front and back. Be sure to remove the foam adhesive that connects the front plate to the motherboard.
Use Ph0 tool to remove the screws holding the motherboard in place.
Gently remove the motherboard from the front plate.
The FLYPAD’s that come with the FPV kit do not have the weights and the rumble motor. The sticks are also not removable.
Pop the joysticks out by pulling gently.
Please add the removal of the motherboard screws. Also I have 3 of these controllers. The oldest has PHILLIPS head screws. The newest has the T6 screws. Just FYI.
Unscrew and replace joystick caps for a more comfortable grip.
The Flypad that comes with the FPV kit does not have removable joystick caps.
Do you know where I can find replacement joystick caps like the one shown in Step 4, please?
Same question as above regarding joystick caps please
