If there are shadows, hair or dust grains on the pictures, then it is recommended to clean the CCD, the recording IC. This guide will show you how to do that.
Images taken with the FS16 of the same object before and after cleaning.
In the second picture the shadows are marked.
The third picture shows a picture after the successful repair
Open the battery compartment cover and remove the battery and the memory card,
Remove the two 4.6 mm # 000 Phillips screws from the bottom near the tripod thread
Remove the single 3.3 mm # 000 Phillips screw from the right side.
Carefully remove the side cover with your hand.
Remove the single 3.3 mm Phillips screw you found underneath the cover.
Remove the four 3.3 mm Phillips screws from the left side
Use a spudger or plastic opener to remove the rear cover. Start next to the USB cover and slide the tool along the camera. Lift the rear housing cover off.
In the second picture you see the camera with the back cover removed.
Carefully lift the keyboard board vertically upwards with your fingers.
Under the keyboard board you will find a gray plastic molding. This part is just jammed and with a bit of patience you can remove it with a spudger. Make sure that none of the sensitive detents break off. Start prying at the bottom.
Concealed in the image by the tool: the display is attached with a 2.0 mm # 000 Phillips screw. Remove that screw
On the opposite side, the display is fixed with a thin piece of sheet metal. Carefully bend the metal away with tweezers or similar tool
Gently flip the display to the right side like a book page.
Under the display is another shielding plate. It is attached with two 6.4 mm #000 Phillips screws. Remove those to remove the shield
Remove the shield
Not to be alarmed: An unused connection will be visible on the display. It is secured with insulating tape. When assembling, push this ribbon cable back under the shielding plate.
The back of the CCD is exposed.
Remove the three 3.0mm # 000 Phillips screws from the back of the CCD
crwdns2935267:0crwdne2935267:0Dust Blower$4.99
Flip the CCD up.
Blow the CCD and the back of the lens out with a few puffs of compressed air or a Dust Blower to remove any dust and lint. Clean both with a lint-free cotton swab and some high-percentage (greater than 95%) alcohol. Let the alcohol dry.
Follow the steps in reversed order to reassemble your device.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Thank you so much for this - much loved little camera saved from the bin!
I'm glad I could help!
VauWeh -
Sehr genaue Anleitung, da kann man gar nichts falsch machen. Zeitaufwand knapp 20 Minuten. Danke!
Vielen Dank für diese Reparatur-Anleitung! Super bebildert und beschriftet, da kann nichts schiefgehen. Für die Schrauben habe ich mir ein Paketband mit der Klebeseite nach oben fixiert, so dass ich diese entsprechend den Arbeitsschritten ablegen kann.
Vielen Dank für die professionelle Reparaturanleitung.
Dirk K
Mit eurer Anleitung hat alles wunderbar gelungen. Leider habe ich ein Schräubchen verloren. Wer hat einen Tip wo ich mir Ersatz besorgen.
