Panasonic RX-11 Camera Repair
  1. Panasonic RX-11 Camera Repair, F02 error / tape slack: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 1) First of all, we have the F02 error which has a fairly simple solution to it. F02 indicates tape slack which means that the cassette is not tightly wound and is quite loose. To fix that all you have to do is:
    • Eject the tape from the camcorder
    • Put a paperclip inside the small hole in the bottom left corner of the cassette
    • Spin the gear on the right counter clockwise wile pressing down lightly onto the "take-up gear", to create resistance and wind the tape tighter. With that done, you should be pretty good to go.
  2. Panasonic RX-11 Camera Repair, U11 error: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 2) U11 error. The U11 error might appear on you camera’s view finder, and will either not record or record unseeable footage. That issue generally indicates a problem with the tape mechanism or with the tape itself, or there could be several issues with the tape mechanism, the most common being dirty drum heads or humidity. To solve that issue:
    • Check if your your cassette is in a good shape and works with other devices, if yes then:
    • ( Solution 1 ), " dirty heads " First take a cotton pad or soft napkin and soak a portion of it in pure alcohol then while holding it with a pair of tweezers
    • Softly rub the soaked side against the drum heads while spinning the drum gently. Continue that process for around two to three minutes without moving around other components inside. Try using the camcorder now, if the error is still there then:
    • ( Solution 2 ) " humidity interference " First take a silica bead packet or more and gently place it inside of the video tape compartment and close it inside
    • Leave it in a dry area of the house where there is little to no humidity and wait a couple of days, after that proceed to "solution 1"
    • Caution! If none of the above work, there is a deeper issue with the camcorder, in that case you will need to take it to a trained professional for part replacements or for tape loader calibration which needs extreme precision.
    • ( How to make my camcorder last longer? ) If your camera is operating properly, to avid future problems ⦿ AVOID rewinding tape with the camera, it can cause loader decalibration due to the delicate mechanism, instead manualy rewind or use a vhs-c adapter and rewind it from your VCR that can handle more heavy duty tasks. ⦿ Keep in dry area.
  3. Panasonic RX-11 Camera Repair, Faulty power switch: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If the camcorder has been sitting under heavy stuff, or handled violently. The power switch tends to go inside of it's socket due to the access force being applied and the age o the plastic holding it in place, that causes the power switch to be unresponsive . To solve that issue:
    • Take a pair of tweezers or small plyers and wrap around the prongs cotton pads or paper to avoid scratching the camcorder
    • With the now cushioned tweezers / plyers grab the switch from inside of it's socket and gently pull it out until you hear a click, the switch should be back into place.
    • After that repair, be gentle with the switch because it's hinges have already been worn out quite a bit and unfortunately there is no way of fixing them.
Philip's retro tech guides
crwdns2935283:005/07/25crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 120
