Panasonic Lumix DMC-GX85 Viewfinder Replacement
  1. Panasonic Lumix DMC-GX85 Viewfinder Replacement, Rear Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Viewfinder Replacement, Rear Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Viewfinder Replacement, Rear Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the plastic hot shoe cover by sliding it towards the rear of the camera.
  2. Panasonic Lumix DMC-GX85 Viewfinder Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Viewfinder Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Viewfinder Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a spudger, gently lift the forward end of the shoe spring to disengage its locking mechanism.
    • While holding the forward end of the shoe spring up, push from its lifted end to remove the shoe spring.
  3. Panasonic Lumix DMC-GX85 Viewfinder Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-GX85 Viewfinder Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 6.0mm silver Phillips #0 screws closest to the display screen.
    • Do not remove the two forward-most silver screws.
  4. Panasonic Lumix DMC-GX85 Viewfinder Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-GX85 Viewfinder Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the camera so the side with the jack cover is facing you.
    • Near the camera's top end, remove the 4.0mm black Phillips #0 screw on the bottom in this orientation.
    • Open the jack cover and remove the 4.0mm black Phillips #0 screw inside.
  5. Panasonic Lumix DMC-GX85 Viewfinder Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-GX85 Viewfinder Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the camera upside down so the bottom of the camera is facing you.
    • Remove the two center 2.5mm black Phillips #0 screws.
    • Remove the outer 4.5mm black Phillips #0 screw.
  6. Panasonic Lumix DMC-GX85 Viewfinder Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Viewfinder Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Viewfinder Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the camera so the display screen is facing you.
    • Rotate the top of the screen away from the camera body to access and remove the 4.5mm black Phillips #0 screw.
    • Remove the rear camera cover by gently pulling from the top side.
    • When removing the rear cover, pull apart slowly to prevent damaging the ribbon cable connecting the display screen and the Sub PCB.
  7. Panasonic Lumix DMC-GX85 Viewfinder Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Viewfinder Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Viewfinder Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the camera so the lens is facing down with the rear cover pulled back.
    • Disconnect the ribbon cable from the camera by pulling up on the black locking tab with an iFixit opening tool.
    • Pull the ribbon cable from the connector. The rear cover is now completely detached from the camera.
    • Do not bend the ribbon cable excessively and take care not to damage the ribbon cable.
  8. Panasonic Lumix DMC-GX85 Viewfinder Replacement, Viewfinder: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Viewfinder Replacement, Viewfinder: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Viewfinder Replacement, Viewfinder: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 4.5mm black Phillips #0 screw under the viewfinder.
    • Gently pull the viewfinder cover from the camera.
  9. Panasonic Lumix DMC-GX85 Viewfinder Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-GX85 Viewfinder Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2.5mm silver Phillips #0 screw located below the viewfinder.
    • Remove the ribbon cable from the underside of the camera by unlatching the black locking tab with an iFixit opening tool then pulling the ribbon away from the connector.
  10. Panasonic Lumix DMC-GX85 Viewfinder Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Viewfinder Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Viewfinder Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the small ribbon cable by gently pulling it away from the camera with ESD safe tweezers.
    • Remove the viewfinder from the camera body.
Kristen Gismondi
crwdns2935283:011/12/14crwdne2935283:0
96.129 crwdns2915208:0crwdne2915208:0
crwdns2935297:0255crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.990crwdne2935297:0
Is it possible to just remove the viewfinder cover seen on step 8 without anything else? (Provided that I have a screwdriver with a flexible end that can fit in there without messing the screen up). Thanks.
Daniel Ristic - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 2,143
