Use this guide to remove the rear cover of the Lumix DMC-GX85 - either to replace a defective or broken display, or to get it out of the way so you can make repairs to other components.
WARNING: Ensure the camera is off before starting!
Remove the plastic hot shoe cover by sliding it towards the rear of the camera.
Using a spudger, gently lift the forward end of the shoe spring to disengage its locking mechanism.
While holding the forward end of the shoe spring up, push from its lifted end to remove the shoe spring.
Remove the two 6.0mm silver Phillips #0 screws closest to the display screen.
Turn the camera so the side with the jack cover is facing you.
Near the camera's top end, remove the 4.0mm black Phillips #0 screw on the bottom in this orientation.
Open the jack cover and remove the 4.0mm black Phillips #0 screw inside.
Flip the camera upside down so the bottom of the camera is facing you.
Remove the two center 2.5mm black Phillips #0 screws.
Remove the outer 4.5mm black Phillips #0 screw.
Turn the camera so the display screen is facing you.
Rotate the top of the screen away from the camera body to access and remove the 4.5mm black Phillips #0 screw.
Remove the rear camera cover by gently pulling from the top side.
Turn the camera so the lens is facing down with the rear cover pulled back.
Disconnect the ribbon cable from the camera by pulling up on the black locking tab with an iFixit opening tool.
Pull the ribbon cable from the connector. The rear cover is now completely detached from the camera.
