Panasonic Lumix DMC-GX85 Rear Cover Replacement
  1. Panasonic Lumix DMC-GX85 Rear Cover Replacement, Rear Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Rear Cover Replacement, Rear Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Rear Cover Replacement, Rear Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the plastic hot shoe cover by sliding it towards the rear of the camera.
  2. Panasonic Lumix DMC-GX85 Rear Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Rear Cover Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Rear Cover Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a spudger, gently lift the forward end of the shoe spring to disengage its locking mechanism.
    • While holding the forward end of the shoe spring up, push from its lifted end to remove the shoe spring.
  3. Panasonic Lumix DMC-GX85 Rear Cover Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-GX85 Rear Cover Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 6.0mm silver Phillips #0 screws closest to the display screen.
    • Do not remove the two forward-most silver screws.
  4. Panasonic Lumix DMC-GX85 Rear Cover Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-GX85 Rear Cover Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the camera so the side with the jack cover is facing you.
    • Near the camera's top end, remove the 4.0mm black Phillips #0 screw on the bottom in this orientation.
    • Open the jack cover and remove the 4.0mm black Phillips #0 screw inside.
  5. Panasonic Lumix DMC-GX85 Rear Cover Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-GX85 Rear Cover Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the camera upside down so the bottom of the camera is facing you.
    • Remove the two center 2.5mm black Phillips #0 screws.
    • Remove the outer 4.5mm black Phillips #0 screw.
  6. Panasonic Lumix DMC-GX85 Rear Cover Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Rear Cover Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Rear Cover Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the camera so the display screen is facing you.
    • Rotate the top of the screen away from the camera body to access and remove the 4.5mm black Phillips #0 screw.
    • Remove the rear camera cover by gently pulling from the top side.
    • When removing the rear cover, pull apart slowly to prevent damaging the ribbon cable connecting the display screen and the Sub PCB.
  7. Panasonic Lumix DMC-GX85 Rear Cover Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Rear Cover Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Rear Cover Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the camera so the lens is facing down with the rear cover pulled back.
    • Disconnect the ribbon cable from the camera by pulling up on the black locking tab with an iFixit opening tool.
    • Pull the ribbon cable from the connector. The rear cover is now completely detached from the camera.
    • Do not bend the ribbon cable excessively and take care not to damage the ribbon cable.
Kristen Gismondi
crwdns2935283:011/12/14crwdne2935283:0
96 135 crwdns2915208:0crwdne2915208:0
crwdns2935297:0255crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021 990crwdne2935297:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 1,470
