Is your blade not spinning when you turn on your device, even when you hear the motor run? Check out this guide to replace your motor shaft.
Remove the dark transparent cap by gently pulling on it.
Remove the back battery cap from the device by twisting it to the unlock position and pulling.
Remove the black trimmer cap from the top of the device by gently pulling it.
Use the metal prying tool to pry apart the silver plastic case .
Pull each side of the plastic case off.
This photo almost made me break my trimmer. You don’t stick your pry tool here but underneath the bottom.
Remove the rubber stopper from the top of the motor shaft by gently pulling it off.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to remove the plastic cover of the motor shaft by pulling it away from the motor.
Hi, when trying to reassemble the trimmer I have a problem with the switch. I do not understand how the mechanical connection between the final switch and the inner one is done. I am wondering if I lost a part…
Thank you, small parts where switch is could be shown as well. Would be very helpful.
Advise for putting things back together: remove plastic switch cover and put back only after full reassembly
Dear Alejandro,
thank You for your instruction, my question is where this motor shaft part is available? I can’t find it anywhere on the net. Thanks if you can help. Bence Fazekas
