Palm Treo 680 screen replacement
  1. Palm Treo 680 screen replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Treo 680 screen replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
  2. Palm Treo 680 screen replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery by pulling it out towards you.
  3. Palm Treo 680 screen replacement, Back Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Treo 680 screen replacement, Back Panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the stylus in order to access the screw.
    • Remove the 27mm top-left screw using a T6 Torx screwdriver.
    Use a T5 Torx screwdriver instead of a T6. T6 is too big.
    Rhebakah Thomas - crwdns2934203:0crwdne2934203:0
    I found T5 too large as well. T4 seeems to work
    Absent Minded Professor - crwdns2934203:0crwdne2934203:0
  4. Palm Treo 680 screen replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Treo 680 screen replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner.
    • Remove the 27mm screw using the T6 Torx screwdriver.
    • If there is a red Palm sticker covering this screw, puncture it to access the screw.
  5. Palm Treo 680 screen replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the remaining two 27mm screws from the bottom using the T6 screwdriver.
  6. Palm Treo 680 screen replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Palm Treo 680 screen replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Palm Treo 680 screen replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the phone so the screen is facing the right side.
    • Use a spudger to carefully separate the back panel from the front panel to access components inside the phone.
    • Separate the covers from the left side of the device as indicated in the picture.
    • The right side contains orange ribbons that are easily damaged.
  7. Palm Treo 680 screen replacement, LCD Screen and Touch Screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Palm Treo 680 screen replacement, LCD Screen and Touch Screen: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Palm Treo 680 screen replacement, LCD Screen and Touch Screen: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers, to carefully peel off the silver tape from the screen.
    • Push the screen out of the back of the front panel to remove it.
  8. Palm Treo 680 screen replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Treo 680 screen replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a small spudger to flip up both of the locking flaps that hold the orange ribbon cables in place.
  9. Palm Treo 680 screen replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Palm Treo 680 screen replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Palm Treo 680 screen replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the screen over 180 degrees and remove the metal piece that cushions the screen.
    • Flip the screen over again.
    • In the following step, you will only slightly pull the screens apart. Do not fully separate them yet.
    • Carefully begin to pull apart the touch screen and LCD screen.
  10. Palm Treo 680 screen replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Palm Treo 680 screen replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Palm Treo 680 screen replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Move your thumbs diagonally to the opposite corner of the screen and slightly pull apart the touch screen from the LCD screen.
    • Carefully peel the touch screen away from the LCD screen.
    • The touch screen and LCD screen should now be completely separated.
To reassemble your device, follow these instructions in reverse order, but ensure you use the new screen. Take your e-waste to an R2 or e-Stewards certified recycler.
Maiya123
crwdns2935283:010/22/09crwdne2935283:0
84 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-4, Maness Fall 2009 crwdns2935289:0Cal Poly, Team 6-4, Maness Fall 2009crwdne2935289:0
CPSU-MANESS-F09S6G4
where can i get the new touch scree, actually my mobile has fallen down and broken the touch scree. i am a resident in India, Andhra Pradesh, Hyderabad........at Ramkote.... please give me message at chinthala.prasad@yahoo.com please
chinthalaprasad - crwdns2934203:0crwdne2934203:0
These are very nice instructions. They are clear and detailed for anyone to follow. Thanks for putting together the steps and sharing it.
I have not tried all steps completely yet. But will do so. I will left with probably a question what to do with touch screen. My phone has
never fallen down nor damaged. It worked perfectly well and one fine day, touch screen stopped working. In any case, I will try.
RJ
Ravi Joshi - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 6,516
