PSP 2000 Analog Stick, D-pad and Action Keys Replacement
  1. PSP 2000 Analog Stick, D-pad and Action Keys Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PSP 2000 Analog Stick, D-pad and Action Keys Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PSP 2000 Analog Stick, D-pad and Action Keys Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place PSP face down, so that the UMD Drive is facing upwards.
    • Locate the battery door and open.
    • Remove the battery from inside.
  2. PSP 2000 Analog Stick, D-pad and Action Keys Replacement, Front Casing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
    • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
    • Remove the sticker using the PSP Opening Tools.
    • Under the sticker is a 5mm Phillips screw needed in the next step.
  3. PSP 2000 Analog Stick, D-pad and Action Keys Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PSP 2000 Analog Stick, D-pad and Action Keys Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four 5 mm Phillips from the case.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
  4. PSP 2000 Analog Stick, D-pad and Action Keys Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PSP 2000 Analog Stick, D-pad and Action Keys Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the following screws from around the bezel:
    • Two 4 mm Phillips
    • One 5 mm Phillips
    • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
    Beware that some models of PSP 2000 (mine is a limited edition Crisis Core FF7 silver version, so I suppose it is related to it being a japanese PSP) have 2 minute TORX screws (T1? T2?) instead of the 2x 4mm Phillips pointed in orange around the USB port.
    Mighty Sashiman - crwdns2934203:0crwdne2934203:0
  5. PSP 2000 Analog Stick, D-pad and Action Keys Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PSP 2000 Analog Stick, D-pad and Action Keys Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pry the front bezel away from the casing using a PSP opening tool.
    • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
    • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
  6. PSP 2000 Analog Stick, D-pad and Action Keys Replacement, Analog Stick, D-pad and Action Keys: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PSP 2000 Analog Stick, D-pad and Action Keys Replacement, Analog Stick, D-pad and Action Keys: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PSP 2000 Analog Stick, D-pad and Action Keys Replacement, Analog Stick, D-pad and Action Keys: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the PSP's faceplate removed, position the PSP so that the analogue stick is easily attainable.
    • Gently pull up on the analogue stick. It should just pop off from the rest of the device.
    • In order to clean it correctly, take a cotton swab w/ rubbing alcohol and clean the base of the analogue stick.
    • The connection point on the PSP should be done as well (where the analogue stick meets the PSP).
  7. PSP 2000 Analog Stick, D-pad and Action Keys Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PSP 2000 Analog Stick, D-pad and Action Keys Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PSP 2000 Analog Stick, D-pad and Action Keys Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the analogue stick has been cleaned, you may wipe the connection points of the D-pad and Action Keys from the PSP to the faceplate.
    • Next, with the faceplate turned upside down, locate the clear/white rubber backing of the D-pad to the left of the display window.
    • Gently peel back and proceed to remove the directional buttons from the faceplate.
    • Now is the time to clean the rubber backing and D-pad with rubbing alcohol, being sure to remove as much dirt and dust as possible.
  8. PSP 2000 Analog Stick, D-pad and Action Keys Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PSP 2000 Analog Stick, D-pad and Action Keys Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This process can also be done to the Action Keys (x, square, triangle, circle).
    • Locate the black rubber backing on the right of the display window and gently remove.
    • Again take a clean cotton swab with rubbing alcohol and clean away all dirt at dust.
    • Now might also be a good time to just clean the surface of the home bar and inspect the home keys if they have dust as well.
crwdns2935229:029crwdne2935229:0
pepe32290
crwdns2935283:010/19/09crwdne2935283:0
1,687 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-3, Maness Fall 2009 crwdns2935289:0Cal Poly, Team 6-3, Maness Fall 2009crwdne2935289:0
CPSU-MANESS-F09S6G3
crwdns2935297:037crwdne2935297:0
crwdns2947412:05crwdne2947412:0
Hi would you pls help check the screw spec ? thanks!
Jacky - crwdns2934203:0crwdne2934203:0
I found <a href=http://www.buyincoins.com>a nice site, where can buy good products, buyincoins</a>- a professional electronics online website, <a href=http://www.buyincoins.com>what let you buy from China directly </a>without any shipping fee. There are Computer Accessories, iPod, iPhone Accessories, HDMI Video Cable, Laser Pointer, Card Reader, Headphone, Silicone Case and more Cool Gadgets.
sophiefish -
I found <a href=http://www.buyincoins.com>a nice site, where can buy good products, buyincoins</a>- a professional electronics online website, <a href=http://www.buyincoins.com>what let you buy from China directly </a>without any shipping fee. There are Computer Accessories, iPod, iPhone Accessories, HDMI Video Cable, LaserPointer, Card Reader, Headphone, Silicone Case and more Cool Gadgets.
sophiefish -
Thanks! very helpful. I use it to clean the “X” button because don’t work. However, still doesnt work i believe is another issue.
Anyway this guide helped me a lot.
Alex - crwdns2934203:0crwdne2934203:0
HEY i helped traduce this guide into spanish at 100% and other of your guides in the traduction panel. I dont know if you need to accept them, i just let you know that there are at 100% thanks for the guide.
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 104
crwdns2936753:030crwdne2936753:0 472
crwdns2942667:0crwdne2942667:0 66,879
