PHILIPS HD8829 coffee machine brewing unit exit funnel Replacement
crwdns2936621:0crwdne2936621:0
  1. PHILIPS HD8829 coffee machine brewing unit exit funnel Replacement, locating the source of leakage: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PHILIPS HD8829 coffee machine brewing unit exit funnel Replacement, locating the source of leakage: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PHILIPS HD8829 coffee machine brewing unit exit funnel Replacement, locating the source of leakage: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After a short run in a dry machine, water was leaking to the side of the machine, and inside a trail of droplets is seen along the brewing unit inside. At the top of the second photo, you can see a large droplet in the side panel.
  2. PHILIPS HD8829 coffee machine brewing unit exit funnel Replacement, remove the brewing unit: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Note that you have to switch the machine off properly, otherwise the brewing unit can't be removed, it is stuck somewhere at the back. If the machine shuts down normally, the brewing unit gets reset to a state where it can can be unmounted.
    • Remove the leak tray
    • Open the side door
    • place 4 fingers in the grip, and push the lever with the thumb, it should come out easily [Video](https://www.youtube.com/watch?v=VcYhWeYP...)
    • This particular one had a strange issue: the feeding funnel connection to the exit tube faced the wrong direction, which meant rotating the top part of the brewing mechanism 180°. Perhaps it was from another machine, perhaps someone else reassembled it incorrectly.
  3. PHILIPS HD8829 coffee machine brewing unit exit funnel Replacement, Rotate the top of the brewing unit: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PHILIPS HD8829 coffee machine brewing unit exit funnel Replacement, Rotate the top of the brewing unit: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • First remove the the feeding funnel by unscrewing the two torx screws.
    • Removing 3 sunken torx screws on the side of the brewing mechanism removes the side plate, so then it can be opened by tilting it a bit around the top part.
    • Assembling it in the right position, taking care that all moving parts sit right fixed the issue.
Om het apparaat weer te monteren, volg je deze instructies in omgekeerde volgorde.
Pieter van der Wolk
crwdns2935283:001/09/23crwdne2935283:0
967 crwdns2915208:0crwdne2915208:0
Hallo. Van mij is er iets mis met het doorloopsysteem. (1) De groene expressoknop brandt onafgebroken en van de 4 rechter rode lampjes knippert het bovenste (geen water) en het onderste (algemene waarschuwing). Wanneer ik op de groene expresseknop druk, doet hij zoals het hoort. Er komt heet water uit de heetwateruitloop, dan knipperen de 3 groene even, en daarna opnieuw van het begin af (1). Het lijkt alsof hij niet uit die subroutine geraakt. De zetgroep is reeds 2x gekuist, het geluid is normaal,...
Wat nu??
Dual - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 45
crwdns2936753:030crwdne2936753:0 120
crwdns2942667:0crwdne2942667:0 1,758
