Ozeino OW810 Motherboard Replacement
  1. Ozeino OW810 Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before beginning this guide make sure you have gathered your tools.
    • You will need The Marlin Screw Driver Set
    • It will take approximately 3 min to get assembled
    • Once your tools are gathered you may begin the guide
  2. Ozeino OW810 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before beginning detach the ear muff
    • Use the Metal Spudger to help detach
    • Highlighted in the red circle is what needs to be detached in order to start the guide
    • Everything will be located on the left side of The Ozeino OW810
  3. Ozeino OW810 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After detaching the ear muff gather your tools
    • You will need The Marlin Screw Driver set
    • Take The Phillips #0 screwdriver to begin
  4. Ozeino OW810 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Highlighted in red is the first screw needed to remove
    • Use Phillips #0 to unscrew
  5. Ozeino OW810 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Highlighted is the second screw needed to be removed
    • Use Phillips #0 screwdriver
  6. Ozeino OW810 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Highlighted is the third screw needed to be removed
    • Use Phillips #0
  7. Ozeino OW810 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Highlighted is the fourth screw needed to be removed
  8. Ozeino OW810 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Highlighted is the fifth screw needed to be removed
  9. Ozeino OW810 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Highlighted is the last screw needed to be removed
    • You should have unscrewed 6 screws from the ear muff
  10. Ozeino OW810 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After unscrewing the screws from the ear muff remove the piece
    • Locate circuit board highlighted
  11. Ozeino OW810 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Highlighted is the screw needed to be removed from the circuit board
  12. Ozeino OW810 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After following the guide and detaching the ear muffs begging locating the plug jack and begin replacement.
    • The replacement should take approximately 10 minutes
    • To reassemble your device, follow these instructions in reverse order.
Ashley Martinez
crwdns2935283:002/21/25crwdne2935283:0
217 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 17-6, Thornton Spring 2025 crwdns2935289:0Sam Houston State, Team 17-6, Thornton Spring 2025crwdne2935289:0
SHSU-THORNTON-S25S17G6
There is a lot of repetition regarding the tools. I recommend being clear in the beginning which tool to use and only repeating when another tool is used. The tools and screws are the main area I would recommend fixing. This is a good guide, and easy to understand.
Morgan G - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 45
crwdns2942667:0crwdne2942667:0 75
