If your Ozeino OW810 gaming headset isn't working and you've already checked that the battery is working, the motherboard may be damaged. The charging port is soldered to the motherboard, so if you suspect the problem is the port, it's necessary to remove the motherboard to desolder and replace the old port.
Before you begin this repair, make sure that the headset is off and unplugged from the charger.
            Before beginning this guide make sure you have gathered your tools.
            You will need The Marlin Screw Driver Set
            It will take approximately 3 min to get assembled
            Once your tools are gathered you may begin the guide
            Before beginning detach the ear muff
            Use the Metal Spudger to help detach
            Highlighted in the red circle is what needs to be detached in order to start the guide
            Everything will be located on the left side of The Ozeino OW810
            After detaching the ear muff gather your tools
            You will need The Marlin Screw Driver set
            Take The Phillips #0 screwdriver to begin
            Highlighted in red is the first screw needed to remove
            Use Phillips #0 to unscrew
            Highlighted is the second screw needed to be removed
            Use Phillips #0 screwdriver
            Highlighted is the third screw needed to be removed
            Use Phillips #0
            Highlighted is the fourth screw needed to be removed
            Highlighted is the fifth screw needed to be removed
            Highlighted is the last screw needed to be removed
            You should have unscrewed 6 screws from the ear muff
            After unscrewing the screws from the ear muff remove the piece
            Locate circuit board highlighted
            Highlighted are the screws needed to be removed from the circuit board
            Remove the motherboard from the headset.
There is a lot of repetition regarding the tools. I recommend being clear in the beginning which tool to use and only repeating when another tool is used. The tools and screws are the main area I would recommend fixing. This is a good guide, and easy to understand.
