Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement
  1. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Thermal Cutoff Fuse: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Thermal Cutoff Fuse: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This is an Oster Digital Electric Kettle
  2. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Remove the bottom: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Remove the bottom: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Remove the bottom: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three screws. They are tri-wing or triangular slotted screws. My set labeled them as number 4.
    • Once removed the plastic cover comes right off.
  3. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Find the Thermal Cutoff Fuse: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Find the Thermal Cutoff Fuse: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Find the Thermal Cutoff Fuse: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The Thermal Cutoff Fuse is pressed up against the heat element by a spring clip.
    • Remove the screw, a standard number 2 phillips head.
    • Slide the fiberglass sleeve down and off the fuse
  4. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Test the fuse: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Test the fuse: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With ohm meter connected either way the fuse is open. A sure sign that the part is bad.
  5. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Verify the new fuse: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Verify the new fuse: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Testing the new fuse shows that electricity can flow through it.
    • I purchased 5x of SF188E 192 10A/250V SEFUSE on ebay. You can just search for whatever is written on the side of yours.
  6. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Replace the fuse: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Replace the fuse: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Replace the fuse. The black band is down in this picture.
    • The difficult part is that this part is not soldered in, it is held together with a crimp band.
    • So one must slowly open the band and then crimp it back on the new fuse.
    • I really have no good way of doing this, and it is the most time consuming and frustrating part of the whole repair. Take your time with a pick and pliers and slowly open them and replace the fuse.
  7. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Put all back together: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Put all back together: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now just slide the fiberglass sleeve back over the fuse.
    • Reattach the spring clip to hold the fuse on the heat element.
    • Make sure that the clip is directly over the fuse before tightening.
    • Replace the plastic cover and install the three tri-wing screws.
  8. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Try it out: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Plug it back in and see if it heats water.
crwdns2935229:022crwdne2935229:0
Scot Henderson
crwdns2935283:005/18/15crwdne2935283:0
1,019 crwdns2915208:0crwdne2915208:0
crwdns2947412:08crwdne2947412:0
Мне нравится этот чайник мне его подарили но проблема у нас электричество на 220 вольт. Вопрос как эго переделать на 220.
digital electronic kettle
Model: BVST-EK5967
120Vac 60HZ
vikangel - crwdns2934203:0crwdne2934203:0
я не думаю, что это будет иметь значение для предохранителя. плавкий предохранитель рассчитан на 250 в, так что это может быть тот же предохранитель в 220 чайника.
я хотел бы посмотреть на предохранитель и посмотреть, если вы можете прочитать его. тогда просто заменить с тем же.
Scot Henderson - crwdns2934203:0crwdne2934203:0
Where is fuse in Oster electric kettle BVSTKT5970
munu88 - crwdns2934203:0crwdne2934203:0
These steps worked fine for me. They are clear and concise. On Step 6, rather than trying to pry the crimp bands off, I cut them off and used new bands that came with the new fuse - much quicker.
Philip McCue - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 77
crwdns2942667:0crwdne2942667:0 19,282
