Osmo Mobile Handle Disassembly
  1. Osmo Mobile Handle Disassembly, Osmo Mobile Handle Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Osmo Mobile Handle Disassembly, Osmo Mobile Handle Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove gimbal from base handle by loosening round plate found at the top of the handle.
    This step isn't clear. How is the ring removed? Twist? Pry?
    Jo Dee Lee - crwdns2934203:0crwdne2934203:0
    Same question for me
    Guitt97ii -
    Tried for hours. Seems it’s glued on?
    ok, the top cap is screwed on. I used a double sided tape around it to have a better grip and just twisted it. The cap has thread lock in it.
    You passed this step?
    Guitt97ii -
    U passed this step???
    Guitt97ii -
  2. Osmo Mobile Handle Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Osmo Mobile Handle Disassembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use Phillips #00 screwdriver to remove the three screws found on the gimbal stabilizer to detach handle from gimbal.
    • Carefully detach handle from gimbal and disconnect the cable that connects the two.
  3. Osmo Mobile Handle Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the hex screws found at the top base of the handle, and unscrew using the 1.5mm hex screwdriver.
  4. Osmo Mobile Handle Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Osmo Mobile Handle Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove joystick by gently pulling away from handle
  5. Osmo Mobile Handle Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Osmo Mobile Handle Disassembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Osmo Mobile Handle Disassembly: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the quick release PCBA by locating the connecting wires and release the ribbon cable with tweezers.
    • Use the spudger to pry open and remove the face plate, starting at the back of the handle.
  6. Osmo Mobile Handle Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Osmo Mobile Handle Disassembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Osmo Mobile Handle Disassembly: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate four screws directly on top of handle.
    • Unscrew the silver, bottom two screws, that are closest to the face plate using the 00 screwdriver.
    • Unscrew the black, top two screws, located furthest from the face plate, using the 0 screwdriver.
    • Remove the remaining two screws found on the front of the faceplate.
    • Remove the rest of the face plate shell.
    hola alguien sabe donde puedo adquirir la face plate shell de refaccion?
    gracias
    jose - crwdns2934203:0crwdne2934203:0
    I know. - Nowhere. You need buy another gimbal (non-working) for a parts. By the way, it will be good to make a manual for other disassembling of a gimbal - I mean rotating parts. Some info of this can be found in this video on Youtube: https://www.youtube.com/watch?v=-5Xi-b8s...
    But not too much :(
    nik_gmp - crwdns2934203:0crwdne2934203:0
Ustena Safa
crwdns2935283:009/28/17crwdne2935283:0
363 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S2-G1, Nance Fall 2017 crwdns2935289:0USF Tampa, Team S2-G1, Nance Fall 2017crwdne2935289:0
USFT-NANCE-F17S2G1
crwdns2947412:010crwdne2947412:0
Bonjour,
La toute première étape est trop vague pouvez-vous donner plus de détails svp.
Je vous remercie d’avance
Guitt97ii - crwdns2934203:0crwdne2934203:0
I would not call that a handle disassembly. This instruction takes you up to the things you need to do PRIOR to disassembly.
I can show you the rest in a video format if you’re interested
John M O'Donovan - crwdns2934203:0crwdne2934203:0
Could you please show me how to fix the USB port that wenr inside the handle? on my Smove gimbal stabilizer
Juan Carlos Beltran -
My osmo has snapped off at the metal camera attachment. Can this be repaired ?
michelle Moore - crwdns2934203:0crwdne2934203:0
Your help would be greatly appreciated
Emile Jansen -
Hi Michelle… The same happened to me… have you gotten yours repaired.?
Emile Jansen - crwdns2934203:0crwdne2934203:0
Hi,
I need to replace my osmo clamp disc and locking knob that hold the phone in place.
I was give this without a manual and snapped the locking knob off.
I thought it had been over tightened.
I was meant to pop it to release the clamp arms and then loosen and lock.
I’ve unscrew the magnet in front and seen behind, I’ve snapped the small screw but half the screw in the other end of the knob.
many thanks.
David Williamson - crwdns2934203:0crwdne2934203:0
what I want to know is where do buy the top face plate?
Irving Aguilera - crwdns2934203:0crwdne2934203:0
I'd like to know where to buy the face plate shell shown being removed in the third jpg in step 6?
Is there any tutorial for DJI Osmo 4?, I need help repairing my OSMO 4 battery. But cant find anything in the internet
Vince Pastor - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 68
crwdns2942667:0crwdne2942667:0 9,036
