Ortizan X10 LED Board Replacement
  1. Ortizan X10 LED Board Replacement, Grille: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ortizan X10 LED Board Replacement, Grille: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool to remove the rubber end caps.
  2. Ortizan X10 LED Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ortizan X10 LED Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ortizan X10 LED Board Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips screwdriver to remove the four screws (two on each end).
    • Firmly grip the top of the speaker, stabilize the base, and twist the cap counterclockwise to loosen and remove. Repeat this step for the bottom cap.
  3. Ortizan X10 LED Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert an opening tool into the seam between the grille and body. Lift and crack it open just a little.
  4. Ortizan X10 LED Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your hands, pull the speaker out of the casing by holding the speaker in one hand and the shell in the other.
  5. Ortizan X10 LED Board Replacement, LED Board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ortizan X10 LED Board Replacement, LED Board: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You can use the iFixit Opening Tool to carefully remove the silicone protective covers at the speaker's top and bottom.
  6. Ortizan X10 LED Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Mahi driver kit and a 1.5 screwdriver bit, remove the two screws that secure the top and bottom of the speaker. Apply firm, even pressure while turning counterclockwise.
  7. Ortizan X10 LED Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ortizan X10 LED Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing the screws, firmly grip the top, stabilize the base, and turn the top counterclockwise (to the left) to loosen and detach it. Repeat the same steps to remove the other side.
  8. Ortizan X10 LED Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the screw that secures the LED circuit board.
  9. Ortizan X10 LED Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pair of tweezers to carefully flip up the small locking flap on the ZIF connector.
  10. Ortizan X10 LED Board Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to gently lift the locking flap on the ZIF connector to release the ribbon cable.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Vainavi
crwdns2935283:003/13/25crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-2, Konn Spring 2025 crwdns2935289:0UMass Dartmouth, Team 4-2, Konn Spring 2025crwdne2935289:0
UMASSD-KONN-S25S4G2
crwdns2942667:0crwdne2942667:0 76
