Optoma HD20 Light Bulb Replacement
  1. Optoma HD20 Light Bulb Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Optoma HD20 Light Bulb Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to loosen the screws that secure the panel on the bottom of the Optoma HD20.
  2. Optoma HD20 Light Bulb Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the panel off of the device.
  3. Optoma HD20 Light Bulb Replacement, Light Bulb Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to loosen the two screws securing the black casing.
    • The screws don't come out all the way.
  4. Optoma HD20 Light Bulb Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Optoma HD20 Light Bulb Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Optoma HD20 Light Bulb Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the light bulb casing from the device.
    • Steps 5-9 are unnecessary if the replacement light bulb comes with housing.
  5. Optoma HD20 Light Bulb Replacement, Light Bulb: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 4.5 mm screws on the light bulb case.
  6. Optoma HD20 Light Bulb Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the light bulb insulator from the light bulb casing.
  7. Optoma HD20 Light Bulb Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the wires off of the pins using tweezers.
  8. Optoma HD20 Light Bulb Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 screws on the back of the light bulb casing using a Phillips #1 screwdriver.
  9. Optoma HD20 Light Bulb Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Optoma HD20 Light Bulb Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the casing, then gently pull out the old light bulb and replace it with the new one.
Trever
crwdns2935283:001/22/15crwdne2935283:0
1.264 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 21-23, Maness Winter 2015 crwdns2935289:0Cal Poly, Team 21-23, Maness Winter 2015crwdne2935289:0
CPSU-MANESS-W15S21G23
crwdns2947412:05crwdne2947412:0
I recently replaced my bulb for the third time and the insulator had grown brittle I am guessing from the heat and it broke. I can't seem to find this part for sale anywhere. Does anyone know if is possible to purchase it?
Thomas - crwdns2934203:0crwdne2934203:0
The screws in step 8 are extremely hard to get off. I went and bought proper screwdrivers before even attempting since theyre small, but in a day I've only managed to get one off and I'm having to resort to other tactics, even using a drill to just grind the heads off.
dv01_ - crwdns2934203:0crwdne2934203:0
king@okinlamps.com
Need LAD60 20PCS
kingshen92 - crwdns2934203:0crwdne2934203:0
The manual says the new light won’t come back on until a lamp reset I’d done via menu , but how can you see the text if the light isn’t on?????
Taringajohn - crwdns2934203:0crwdne2934203:0
my hd 20 projects dull images i recently replaced my bulb for the first time successfully and i followed as per menu trying to bulb reset but it is not working and still image is dull how to solve the problem
kumar - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 12,038
