Optical Bay Enclosure Dual Hard Drive Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Optical Bay Enclosure Dual Hard Drive Replacement, Dual Hard Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Optical Bay Enclosure Dual Hard Drive Replacement, Dual Hard Drive: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic positioner from the optical bay hard drive enclosure by pressing in on one of the clips on either side and lifting it up and out of the enclosure.
    What’s the switch for on the inside of the caddy? What position should it be in? Mine came switched to the right (towards SATA connector that disk inserts into).
    Robert Lord - crwdns2934203:0crwdne2934203:0
  2. Optical Bay Enclosure Dual Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Optical Bay Enclosure Dual Hard Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Optical Bay Enclosure Dual Hard Drive Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure that the hard drive connectors are facing down before placing it into the enclosure.
    • Gently place the hard drive into the enclosure's hard drive slot.
    • While firmly holding the enclosure in place with one hand, use your other hand to press the hard drive into the enclosure connectors.
  3. Optical Bay Enclosure Dual Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Optical Bay Enclosure Dual Hard Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the hard drive is snug, reinsert the plastic positioner while holding the hard drive against the bottom of the enclosure.
    • Reconnect any cables you have removed from the original optical drive onto the optical bay enclosure.
    Why no mention of attaching the new hard drive to the Optical Drive Enclosure using the enclosed phillips screws?
    Once you have securely inserted the new hard drive into the Optical Drive Enclosure and replaced the plastic positioner you should attach the drive to the enclosure using two of the provided phillips screws. Two holes on the underside of the enclosure should align with two attachment holes on the underside of the drive.
    nickmalmquist - crwdns2934203:0crwdne2934203:0
    I suspect that the plastic positioner will secure the drive well enough (for this style of adapter). As I mentioned in earlier comment, this should mean you can replace / upgrade the SATA drive later without needing to remove the adapter, skipping many steps.
    Les Kitchen -
    Do you need a sata cable to connect the new drive to the board or does it connect via the optical drive cable that we disconnected earlier?
    Erik Sawaya - crwdns2934203:0crwdne2934203:0
    It does connect to the optical drive cable but if you don't use the optical bay enclosure you'll need a 13 pins to 22 pins sata adaptor (and some tape!)
    The sata cable for the optical drive has 6 + 7 pins while ssd and hhd have 15 + 7 pins
    Graziano Nora - crwdns2934203:0crwdne2934203:0
    Can someone please explain why you need to remove the black plastic faceplate  from the optical bay enclosure. It is designed to receive the standard SSD. What is gained from removing a part of it?
    Peter Bull - crwdns2934203:0crwdne2934203:0
    Thank you! This guy has made upgrading the mid 2010 iMac I inherited from my mom MUCH easier and saved me a lot of time, trial, and error.
    Rob Anthony Dire - crwdns2934203:0crwdne2934203:0
    My Penrynn Super Drive has PATA connector, and now is a fossil grade rarity :-(
    IMI Comp - crwdns2934203:0crwdne2934203:0
    I'm a little confused. Do I need the enclosure from ifixit or am I removing the optical drive and installing an ssd in the preexisting op drive enclosure? If using the already existing enclosure what type of ssd do I need as for Sata connectors?
    danielpainter65 - crwdns2934203:0crwdne2934203:0
Brittany McCrigler
crwdns2935283:003/05/12crwdne2935283:0
89 977 crwdns2915208:0crwdne2915208:0
crwdns2935297:0142crwdne2935297:0
Staff
crwdns2935297:019 980crwdne2935297:0
Great guide, however I think you overestimated the difficulty of it. The biggest challenge is not stripping any screws and being sure to have all sizes that you may possibly need including some that might not be standard because stripping screws is very possible. Otherwise, nice job
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 285
