Opening the Huawei Watch 3
    • User your fingernail to pull the small metal pin on each wrist band towards the inside. This unlocks the wrist bands from the body of the watch.
    • Remove the wrist bands.
  1. Opening the Huawei Watch 3, Remove the four Torx screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Torx T3 screwdriver to remove the four 4 mm-long screws on the back of the Huawei Watch 3.
  2. Opening the Huawei Watch 3, Pry the back cover open: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Opening the Huawei Watch 3, Pry the back cover open: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Opening the Huawei Watch 3, Pry the back cover open: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the small notch at the top of the back cover.
    • Use a Jimmy to pry open the back cover by twisting it.
    • Using a sharp metal tool might cause cosmetic damage to the watch case. Covering the tool with a nitril glove can minimize the damage.
    • Don’t remove the back cover just yet. It is still connected to the motherboard with a flex cable.
  3. Opening the Huawei Watch 3, Loosen the back cover gasket: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Opening the Huawei Watch 3, Loosen the back cover gasket: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the tip of an opening pick between the back cover and the case.
    • Slide the opening pick around the back cover to loosen the gasket from the back cover.
  4. Opening the Huawei Watch 3, Lift the back cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Opening the Huawei Watch 3, Lift the back cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Opening the Huawei Watch 3, Lift the back cover: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There is a ribbon cable running from the back cover to the motherboard.
    • Use an opening pick or your fingers to carefully lift the back cover open.
    • Flip the back cover open away from the crown.
    • You can prop up the back cover to minimize the stress on the ribbon cable.
  5. Opening the Huawei Watch 3, Remove the battery bracket screw: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the 2.9 mm-long screw from the battery bracket.
  6. Opening the Huawei Watch 3, Remove the battery bracket: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Opening the Huawei Watch 3, Remove the battery bracket: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Opening the Huawei Watch 3, Remove the battery bracket: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • User a pair of tweezers to lift the top of the battery bracket free from its screw socket.
    • Unhook the opposite side of the bracket and remove it.
  7. Opening the Huawei Watch 3, Unplug the battery connector: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Opening the Huawei Watch 3, Unplug the battery connector: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to pry up and disconnect the battery connector.
    • The battery connector is the smallest of the three connectors.
  8. Opening the Huawei Watch 3, Remove the sensor bracket screw: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the 2.9 mm-long screw from the sensor bracket.
  9. Opening the Huawei Watch 3, Remove the sensor bracket: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Opening the Huawei Watch 3, Remove the sensor bracket: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Opening the Huawei Watch 3, Remove the sensor bracket: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • User a pair of tweezers to move the top of the sensor bracket free from a small latch near the case by rotating in inwards.
  10. Opening the Huawei Watch 3, Unplug the sensor connector: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Opening the Huawei Watch 3, Unplug the sensor connector: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Opening the Huawei Watch 3, Unplug the sensor connector: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tip of a spudger to pry up and disconnect the sensor connector.
    • Remove the back cover.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our https://www.ifixit.com/Answers/Device/Hu... for help.
Tobias Isakeit
crwdns2935283:003/31/14crwdne2935283:0
126 985 crwdns2915208:0crwdne2915208:0
crwdns2935297:0189crwdne2935297:0
Tobias Isakeit - Repairability Engineer crwdns2935289:0Tobias Isakeit - Repairability Engineercrwdne2935289:0
Business
crwdns2935297:01 143crwdne2935297:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 60
crwdns2936753:030crwdne2936753:0 226
crwdns2942667:0crwdne2942667:0 3,611
