Opening The Main Cover Of The HP 255 G7
  1. Opening The Main Cover Of The HP 255 G7, Flip The Laptop Upside Down: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Firstly, flip the laptop upside down, so that you are looking at the bottom of it, and the hinge of the screen is facing away from you.
  2. Opening The Main Cover Of The HP 255 G7, Remove The Rubber "Leg": crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Opening The Main Cover Of The HP 255 G7, Remove The Rubber "Leg": crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the metal spuger (or another tool, just make sure its not too sharp) to remove the rubber "leg", all the way until it is completely removed.
  3. Opening The Main Cover Of The HP 255 G7, Remove The Upper Rubber "Leg": crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat for the top rubber.
  4. Opening The Main Cover Of The HP 255 G7, Unscrew: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Opening The Main Cover Of The HP 255 G7, Unscrew: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Opening The Main Cover Of The HP 255 G7, Unscrew: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew all the screws from the laptop, including the ones that were under the rubber "legs".
    • There should be 11 screws in total. (4 under the upper leg, 3 under the lower one, and 4 that were not under rubber).
  5. Opening The Main Cover Of The HP 255 G7, Start Inserting The Picks: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully insert a pick under the touchpad of the laptop.
  6. Opening The Main Cover Of The HP 255 G7, Continue Inserting Picks: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Continue inserting picks all the way around the laptop.
  7. Opening The Main Cover Of The HP 255 G7: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull apart the cover and the body of the laptop.
    • If you find resistance, reduce the angle of the screen hinge, since the hinge might be "clamping" the cover.
    • If you still find resistance, check for any forgotten screws on the bottom. Never apply too much pressure if there is a lot of resistance.
  8. Opening The Main Cover Of The HP 255 G7: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Finally, the bottom of the laptop should look like that.
Stratos Thivaios
crwdns2935283:002/27/23crwdne2935283:0
1,357 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 29
crwdns2936753:030crwdne2936753:0 161
crwdns2942667:0crwdne2942667:0 3,472
