Opening Procedure
crwdns2942287:0crwdne2942287:0This is a prerequisite-only guide! This guide is part of another procedure and isn't meant to be used alone.
This guide shows how to open the Scuf Reflex controller for repairs.
Before starting repairs, turn off your device and unplug any cables.
Insert the flat end of a spudger between the faceplate and the R1 bumper.
Pry up with the spudger to release the clips securing the bumper.
Remove the R1 bumper.
Insert the flat end of a spudger between the faceplate and the L1 bumper.
Remove the L1 bumper.
At the bottom tip of the right grip, insert the flat end of a spudger or a clean fingernail between the faceplate trim and the back cover.
Pry up to release the faceplate trim’s bottom right clip.
At the bottom tip of the left grip, insert the flat end of a spudger or a clean fingernail between the faceplate trim and the back cover.
Pry up to release the faceplate trim’s bottom left clip.
Insert the flat end of a spudger between the faceplate trim and the back cover, next to the headphone jack.
Pry up to release the plastic clips securing the center of the faceplate trim.
Lift the bottom edge of the faceplate trim and thread it up and over the thumbsticks.
Pull the top corners of the faceplate trim out from underneath the faceplate and remove the faceplate trim.
Pull the thumbsticks straight up and off of their joysticks to remove them.
Use a Phillips screwdriver to remove the four 6.5 mm-long screws securing the back cover, two near the triggers and two at the bottoms of the grips.
Insert a spudger underneath the bottom right corner of the faceplate and pry up to release the plastic clip.
Insert a spudger underneath the bottom left corner of the faceplate and pry up to release the plastic clip.
Insert the flat end of a spudger between the plastic clip next to the headphone jack and the faceplate.
Pry the plastic clip away from the faceplate to release it.
Repeat to release the second clip.
Insert the flat end of a spudger between the right edge of the faceplate and the back cover.
Pry down to release the plastic clip securing the faceplate.
Insert the flat end of a spudger between the left edge of the faceplate and the back cover.
Carefully lift up the bottom of the faceplate assembly.
Pull the faceplate assembly down and remove it.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
