OnePlus Nord Screen Replacement
Adriana Zwink
crwdns2944107:0crwdnd2944107:0Adriana Zwinkcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mud 27, 2024crwdne2944111:0
crwdns2931287:050crwdne2931287:0 - crwdns2931289:01crwdne2931289:0
crwdns2937801:0crwdne2937801:0
crwdns2862627:0crwdne2862627:0
crwdns2942287:0crwdne2942287:0
Use this guide to replace a cracked or broken screen on your OnePlus Nord.
If the frame is deformed, it's important to replace it to make sure the new screen will mount correctly and won’t suffer damage from uneven pressure.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
Note: This guide instructs you to replace only the screen while leaving the original frame and motherboard in place. However, some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires a very different procedure. Make sure you have the correct part before starting this guide.
You’ll need replacement adhesive to reattach components when reassembling the device.
crwdns2944105:0crwdne2944105:0
  1. OnePlus Nord Screen Replacement, Loosen the rear glass adhesive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Switch off your phone.
    • Heat an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. If you have a heatbed with precise temperature control (like any FDM 3D printer with heatbed) 45°C is enough. You might want to repeat this step several times during the rear glass removal.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
    I needed 4 hands to do this. And good light to see the gap.
    Roger Bratseth - crwdns2934203:0crwdne2934203:0
  2. OnePlus Nord Screen Replacement, Create a gap: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OnePlus Nord Screen Replacement, Create a gap: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply a suction cup to the back of the phone, as close as possible to the center of the right edge.
    • Pull on the suction cup to create a gap between the rear glass and the frame.
    • Insert an opening pick into the gap.
  3. OnePlus Nord Screen Replacement, Slice the adhesive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OnePlus Nord Screen Replacement, Slice the adhesive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick along the edge to the bottom right corner.
    • Leave the opening pick in its place to prevent the adhesive from resealing.
    • Once you have inserted an opening pick, feel free to remove the suction cup or continue to use it for a better grip during this process.
  4. OnePlus Nord Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 OnePlus Nord Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 OnePlus Nord Screen Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a second opening pick under the bottom right corner.
    • Slide the opening pick along the edge to the top right corner.
    • If you have trouble with cutting, you can use the iOpener again to soften the adhesive.
  5. OnePlus Nord Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 OnePlus Nord Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 OnePlus Nord Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a third opening pick under the top right corner of the back cover.
    • Slide the tip of the opening pick along the edge of the phone to the top left corner to cut the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. OnePlus Nord Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 OnePlus Nord Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 OnePlus Nord Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a fourth opening pick under the top left corner.
    • Slide the opening pick along the edge to the bottom left corner to cut the adhesive.
  7. OnePlus Nord Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OnePlus Nord Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a fifth opening pick under the bottom left corner.
    • Slide it along the the edge to the bottom right corner to cut the remaining adhesive.
  8. OnePlus Nord Screen Replacement, Remove the back cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover.
    • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  9. OnePlus Nord Screen Replacement, Remove the motherboard cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the ten 3.6 mm-long screws from the motherboard cover.
    One of the screws has a thin white, flush surface on top that you need to break with your screwdriver.
    There is also an 11th screw, already removed in the picture, left of the third camera from the top. Making it 10 normal screws and the 11th white one. bottom right
    Steven - crwdns2934203:0crwdne2934203:0
  10. OnePlus Nord Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 OnePlus Nord Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 OnePlus Nord Screen Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of an opening pick under the motherboard cover.
    • Use the opening pick to lift the motherboard cover up and release the plastic clips that holds the cover in its place.
    • Remove the motherboard cover.
  11. OnePlus Nord Screen Replacement, Disconnect the battery: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OnePlus Nord Screen Replacement, Disconnect the battery: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the battery by prying the connector straight up from its socket.
  12. OnePlus Nord Screen Replacement, Remove the daughterboard cover: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the seven 3.6 mm-long screws.
  13. OnePlus Nord Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 OnePlus Nord Screen Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 OnePlus Nord Screen Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of an opening pick under the daughterboard cover.
    • Pry up to release the clips holding the daughterboard cover in place.
    • Remove the daughterboard cover.
  14. OnePlus Nord Screen Replacement, Disconnect the display connector: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OnePlus Nord Screen Replacement, Disconnect the display connector: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat edge of a spudger to pry up and disconnect the display connector from its daughterboard socket.
  15. OnePlus Nord Screen Replacement, Apply a heated iOpener: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a Heat an iOpener to the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    On my two phones I didn't need to apply heat to remove the screen. No glue that I could see.
  16. OnePlus Nord Screen Replacement, Create a gap: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 OnePlus Nord Screen Replacement, Create a gap: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 OnePlus Nord Screen Replacement, Create a gap: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction cup to the right edge of the display.
    • If the phone's screen is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Pull up the suction cup with strong, steady force to create a gap.
    • Insert the point of an opening pick into the gap and slide it to the bottom right corner.
  17. OnePlus Nord Screen Replacement, Slice the adhesive: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 OnePlus Nord Screen Replacement, Slice the adhesive: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 OnePlus Nord Screen Replacement, Slice the adhesive: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a second opening pick at the bottom right corner.
    • Slide the opening pick along the edge to the top right corner of your phone.
    • Leave both opening picks in their place to prevent the adhesive from resealing.
  18. OnePlus Nord Screen Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 OnePlus Nord Screen Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 OnePlus Nord Screen Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a third opening pick under the top right corner.
    • Slide the opening pick along the edge to slice the adhesive.
  19. OnePlus Nord Screen Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 OnePlus Nord Screen Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 OnePlus Nord Screen Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick along the edge to cut the adhesive.
    • Leave the opening pick in the bottom left corner so prevent the adhesive from resealing.
  20. OnePlus Nord Screen Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OnePlus Nord Screen Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide it along the bottom edge to cut the remaining adhesive.
    • Do not remove the screen completely yet. The display cable is still threaded through the frame.
  21. OnePlus Nord Screen Replacement, Remove the display: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 OnePlus Nord Screen Replacement, Remove the display: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 OnePlus Nord Screen Replacement, Remove the display: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully thread the display cable through the frame.
    • Remove the display.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
crwdns2935229:029crwdne2935229:0
Adriana Zwink
crwdns2935283:012/18/19crwdne2935283:0
58,382 crwdns2915208:0crwdne2915208:0
crwdns2935297:0167crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,281crwdne2935297:0
crwdns2947412:015crwdne2947412:0
So essentially the greater part of the guide is only necessary because OnePlus decided to have the display connector at the back of the phone rather than at the front under the display? What a poor choice repairability-wise on their side, very disappointing! Otherwise great guide.
Nikola Steffanov - crwdns2934203:0crwdne2934203:0
Hi Nikola, yes, this is troublesome! Indeed, you have to make a few moves until it is possible to remove the display. Unfortunately, there is no easier way.
Adriana Zwink -
Yes!, I had the same problem, I spent all day trying different ways to get out like three pesky screws. :( Any tips from anybody? I scoured the internet for a few hours, tried a few different things already but any help would be much appreciated!
Matt Farel -
Why do guides only show you how to take apart screens and not how to apply a new one?
Tee Jay - crwdns2934203:0crwdne2934203:0
Hi @Tee Jay, to reassemble your OnePlus Nord and install the new screen, follow the steps in this guide in reverse order.
Adriana Zwink -
But how do I apply the screen again? What kind of glue should I use and where do I put it?
David Markert -
GREAT guide ... congratulations !!!
Nico - crwdns2934203:0crwdne2934203:0
Hi Nico, thank you!
Adriana Zwink -
Hi what if I don't need to replace the display at all and just the glass I'm having a tough time finding a proper way to do that
Mr Gentle - crwdns2934203:0crwdne2934203:0
Is this guide relevant to the Nord N10 5G?
west bel - crwdns2934203:0crwdne2934203:0
Where can I buy the screen? I can't find it on the site.
Nord repair - crwdns2934203:0crwdne2934203:0
Bonjour, Merci pour ce tutoriel. Vous parlez d'adhésif pour le remontage. Quel est le type de l'adhésif nécessaire et pour quelles pièces est-il nécessaire?
Merci.
Pierre S.
pierre sancho - crwdns2934203:0crwdne2934203:0
Bonjour @pierresancho, excellente question ! Soit votre écran de rechange est muni de bandes adhésives préinstallées, auquel cas il suffit de bien nettoyer les zones d'adhérence sur le téléphone avant de monter le nouvel écran. Soit vous prenez des morceaux d'adhésif correspondant à ces zones d'adhérence pour fixer votre écran, par exemple en suivant ces instructions (lien vers l'adhésif nécessaire inclus) : https://fr.ifixit.com/Tutoriel/Comment+u...
Claire Miesch -
Which size of adhesive tape is necessary? How broad does the tape need to be (in mm) and how much of it (in cm) will I need?
Welche Breite (in mm) und insgesamte Länge (in cm) ist notwendig?
Samae1 - crwdns2934203:0crwdne2934203:0
Be very careful when removing the back-glass and use plenty of heat all over the surface and not just along the edge. There is some adhesive above the battery, next to the camera, that will be holding on even though all the adhesive along the edge is gone.
I managed to crack the back glass because of this adhesive due to not being careful enough. Not that it matters for me as this was just a data recovery procedure for me.
gurragutta - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 23
crwdns2936753:07crwdne2936753:0 185
crwdns2936753:030crwdne2936753:0 857
crwdns2942667:0crwdne2942667:0 75,281
