This guide demonstrates how to remove the midframe of the OnePlus Nord N200 phone.
Insert the Jimmy into the seam between the rear glass and the midframe at the bottom edge of the phone to create a gap.
Insert an iFixit opening pick into the gap you created with the Jimmy.
Slide the Jimmy around the phone to slice the adhesive.
Insert a second iFixit opening pick at the spot you have sliced open to keep it open.
Slide the iFixit opening pick along the top edge to slice the adhesive.
Start prying the back plate off the phone.
Use a Phillips #00 screwdriver to remove the sixteen 3.6 mm-long screws securing the midframe.
Gently insert the Jimmy to create a gap between the midframe and the top of components in the bottom case.
Slide an opening pick around the edge of the midframe to slice the adhesive.
Use the Jimmy to pry off the midframe of the phone.
Use your hands to finish prying open the midframe off the phone.
Pull the midframe off of the phone and lay it to the side of the phone.
Place a spudger or an opening tool under the connector's edge and pry straight up to disconnect the fingerprint cable connector.
Move the fingerprint reader cable to the side along with the midframe.
To reassemble your device, follow these instructions in reverse order.Take your e-waste to an R2 or e-Stewards certified recycler.
