OnePlus 6 Battery Replacement
crwdns2869540:0crwdne2869540:0: 32 тыс.
9
69
361
31 755
crwdns2955950:0crwdne2955950:0: 11
crwdns2960004:05crwdne2960004:0, crwdns2960008:06crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 17
crwdns2959974:017crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 2
crwdns2959982:02crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 25 - 30 crwdns2931279:0crwdne2931279:0
If you are having problems with your OnePlus 6 not holding a charge or not powering on, use this guide to replace your phone’s battery.
The battery of a phone is what gives the phone power and having a good battery is key to a long phone life.
From time to time, the battery life of a phone, even in the OnePlus 6, may be depleted over time and cause you some frustration. These problems can come from a variety of things like overloading the phone with too many apps running to simply having a faulty and depleted battery. Be sure to check out the OnePlus 6 Troubleshooting page to see if there is a easy fix before taking action to replace anything. If nothing is working, this step-by-step process will guide you through replacing your old battery with a new one so you can get your OnePlus 6 back to running like new.
The first step in this replacement guide is to remove the back panel of the phone, the back panel is made of glass so be careful not to shatter it. Also, be on the lookout for a swollen battery as it can be a fire and explosion hazard.
Be sure to disconnect any power sources and shutting down the phone before beginning the replacement process.
    1. OnePlus 6 Battery Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
      • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
      • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
      • Repeat until the back panel is fully released.
    2. OnePlus 6 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OnePlus 6 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
    3. OnePlus 6 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OnePlus 6 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
      • Completely remove the back panel from the device.
    1. OnePlus 6 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OnePlus 6 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Grip the green tab connected to the battery and pull the battery directly up and out.
For optimal performance, after completing this guide, calibrate your newly installed battery.
crwdns2935229:017crwdne2935229:0
John Steven Trammell
crwdns2935283:009/28/21crwdne2935283:0
961 crwdns2915208:0crwdne2915208:0
Clemson, Team 4-3, Hunter Fall 2021 crwdns2935289:0Clemson, Team 4-3, Hunter Fall 2021crwdne2935289:0
CLEM-HUNTER-F21S4G3
crwdns2935297:096crwdne2935297:0
How do I glue the phone back together when I am done? Do I need to add more glue? Do I just heat it with the heat gun again and squeeze it together?
Timothy Magee - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I agree, this is unclear.
The "Parts" section at the top includes "Precut adhesive card", but when you click on that item, it gives a whole bunch of different size options for rolls of tape (8mm, 5mm, 1mm, etc.) and it's unclear which size to get. Does anyone have details of this?
Greg - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Great tutorial, battery is fixed thank you ! If you prefer videos, this one is a good complement https://www.youtube.com/watch?v=OBN7Tc7J...
Kergara B - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Battery good so far, instructions clear enough! I turned the phone on immediately after replacing the battery to make sure everything worked. This was to avoid putting the phone back together only to find it wouldn't turn on, and then having to dismantle it again.
One thing you may want to pay attention to is not to separate the screen (front) layer from the phone, rather than the back side, which is what I did on my first try.
I opted not to get adhesive strips and I simply applied thinly cut electrical tape around the phone's edges, on the outside, to keep it together after fixing. Not terribly aesthetic but does the job well enough, especially if you use a book-style phone case like me.
Pretty doable fix for a first-timer, especially when using the fixit tools (picks, spudgers etc). Happy with the results. Thank you for the guide!
Nic F - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Additional tips (1/2):
1. When buying tools, consider buying a suction handle. This was useful to use on the heated back cover to open up a gap to insert the opening picks into.
2. Consider removing the SIM tray before heating the back cover.
3. When heating the glass back cover, consider wearing some resistant gloves when heating the glass back cover. The glass can get a little got and I was only using a hair dryer on the highest setting, rather than a heat gun.
4. When you have managed to wedge your first opening pick underneath the back cover, take another pick and drag it along the nearest part of the gap to open up the gap further before setting that pick into position. Repeat as you go around the entire edge of the phone. However, BE CAREFUL to not push the opening pick too deep, especially around where the volume buttons are, as the fingerprint sensor cable is located close the edge of the phone.
Adrian Wan - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 69
crwdns2936753:030crwdne2936753:0 361
crwdns2959996:0crwdne2959996:0 31,755
