OnePlus 5 Fingerprint Scanner Replacement
crwdns2942287:0crwdne2942287:0Follow this guide to remove and replace a defective fingerprint scanner/home button for the OnePlus 5. The fingerprint scanner is layered underneath the loudspeaker module and the daughterboard. The hardest part of the guide is getting the frame clips of the back cover free to access the internals of the phone.
Some guide images will show the battery already removed from the phone. You do not need to remove the battery for this procedure.
crwdns2944105:0crwdne2944105:0
Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole below the SIM card tray, located near the rear cameras on the edge of the phone.
Press firmly to eject the tray.
Remove the two 2.6 mm T2 screws straddling the USB-C port on the bottom edge of the phone.
Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
Frame seam: This is where the plastic frame meets the back cover. Only pry at this seam.
There are twelve clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
Place a suction cup near the bottom edge of the display.
Pull on the suction cup with strong steady force.
Press the edge of an opening tool straight into the frame seam near the suction cup until the edge wedges between the plastic frame and the back cover's lip.
Once the opening tool's edge is wedged in position, carefully slide the tool along the bottom edge of the phone.
Carefully guide the opening tool around the left corner of the phone while keeping the tool's edge within the seam.
Lever the opening tool to release the first clip from the frame.
Continue sliding the opening tool along the long edge, releasing the clips along the way.
With the bottom and left edge of the phone freed, gently wiggle the frame to release the top and right edge clips.
Align the top edge of the frame to the back cover and ensure that the top clips slip into place.
Squeeze along the long edges of the phone to snap the remaining clips into place.
With all the clips released, flip the phone over so that the display is face-down.
Swing the back cover around and rest it on top of the exposed frame.
Remove the 2.6 mm Phillips screw holding the cable bracket above the battery in place.
Lift up and remove the cable bracket.
Use the point of a spudger to pry up and disconnect the back cover flex cable from its socket.
Use the point of a spudger to pry up and disconnect the battery connector from its socket.
Remove the six 2.6 mm Phillips screws securing the loudspeaker to the frame.
Insert the flat end of a spudger into the corner of the loudspeaker assembly and pry slightly, loosening the loudspeaker from its recess.
Use the point of a spudger to pry up and disconnect the interconnect flex cable from the socket.
Use the point of a spudger the pry up and disconnect the fingerprint scanner connector from its socket on the daughterboard.
Slip the point of a spudger underneath the antenna interconnect cable and pry up to disconnect it from its socket on the daughterboard.
De-route the antenna interconnect cable out of the way of the daughterboard.
Insert the edge of a flat end of the spudger underneath the microphone board and twist slightly to release the board's adhesive.
Slide the flat end of a spudger or the point of an opening pick underneath the daughterboard near its right edge.
Gently pry to loosen the daughterboard from its recess.
Insert the flat end of a spudger underneath the daughterboard, this time approaching it from the bottom.
Twist and slide the spudger slightly to release the daughterboard from its recess.
crwdns2935267:0crwdne2935267:0Electrical Tape in 6 Assorted Colors$9.99
Slide the flat end of a spudger underneath the tape covering the fingerprint scanner.
Lift up to pry and remove the tape.
Use your finger to gently lift up the connector end of the fingerprint scanner. Pull upwards slowly. Do not pull directly away from the fingerprint scanner.
Keep pulling upwards until the fingerprint scanner cable is freed from its recess.
Insert the point of a spudger into the marked areas on either side of the flex cable, and push until the fingerprint scanner is loosened from its recess.
Once the fingerprint scanner is loosened from its recess, carefully thread its flex cable through the cutout, out of the front of the display.
Remove the fingerprint scanner.
Repair didn’t go as planned? Check out our OnePlus 5 Answers Community for troubleshooting help.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:08crwdne2947412:0
Is there an extra step involved so that the button stays countersunk in the new display? Mine seems to be slightly proud of the screen
Hi John,
If you may need to apply some new adhesive to the underside of the fingerprint sensor to hold it in place.
Hi,
I change the fingerprint but only works if don’t close the back cover, when I close the back cover the OS don’t detect the fingerprint sensor. Any idea?
Hey César,
It may be that something is shorting the fingerprint sensor. Did you replace the tape in step 24 with electrical tape?
Great news, finally I found the problem, the connector from daughter board to motherboard was disconnected but a lot of pins maked contact and the micro, and other electronics works but not the fingerprint sensor. I dissasembled the motherboard and pushed the connector from the flex cable to the socket, now all is working ok. Thanks for the response Arthur!
I’m glad you fixed the problem! Thanks for following up!
Hello everyone ! I’m trying to fix my oneplus 5 too. I’m currently replacing the home button but it does not stay in place (the button just ‘stick out’ from the screen). @arthurshi Does the home button must have an ‘adhesive band’ to stick to the screen ? It does not seems to be a clip-able button. I’m not talking about this side https://d3nevzfk7ii3be.cloudfront.net/ig... . I’m talking about the other, the black ‘screen’ side.
Thank you for your work.
Hi Michaël!
Good question! The button does have some adhesive on it. If the existing adhesive no longer holds the button, I suggest using some double-sided tape to hold the button in place. If you are certain your repair fully works, you can also glue the button down with a bit of E6000 adhesive.
