OneLink Safe and Sound Battery Replacement
  1. OneLink Safe and Sound Battery Replacement, Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OneLink Safe and Sound Battery Replacement, Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Run the metal spudger under the plastic rim and around the perimeter, on the top of the device to loosen the adhesive.
    • Remove plastic rim.
  2. OneLink Safe and Sound Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OneLink Safe and Sound Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove nine screws from the top of the device.
  3. OneLink Safe and Sound Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OneLink Safe and Sound Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Don't yank or pull the lid off as there are ribbons and cables connecting the top of the device to the motherboard. They need to be disconnected before the top is removed.
    • Use tweezers or a spudger to disconnect the ribbon from the motherboard.
  4. OneLink Safe and Sound Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to unplug the speaker cable from the motherboard.
  5. OneLink Safe and Sound Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OneLink Safe and Sound Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool to remove the microphone connection from the motherboard.
    • Remove the top of the device.
  6. OneLink Safe and Sound Battery Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to disconnect the cable from the motherboard.
  7. OneLink Safe and Sound Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OneLink Safe and Sound Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the single screw securing the plastic battery cage.
  8. OneLink Safe and Sound Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OneLink Safe and Sound Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic cage holding the battery in place.
    • Remove the battery from the device.
    Amazing!!! Got my smoke detector fixed.
    Thank you very much!!!
    Jose Chocano Felice - crwdns2934203:0crwdne2934203:0
    I appreciated that you shared this! Do you mind sharing what glue you use to put it back together? Do you have battery recommendation? I purchased this 3v battery from amazon: https://www.amazon.com/dp/B09CLGNQP7?psc... (2CR17335A) for $20.98. I'm not sure if it works yet -- still need to do the soldering. I plan to unsolder the wire from the previous battery and solder it to the new one (the connector to the system board is different).
    Tim - crwdns2934203:0crwdne2934203:0
    Got mine up and running again. Found a 2 pack of batteries on Amazon for around $18. Easy enough repair. Thanks for the how to.
    dan oleary - crwdns2934203:0crwdne2934203:0
    can some one tell me if the batteries are non rechargable?
    Lenny - crwdns2934203:0crwdne2934203:0
Arianna Roberts
crwdns2935283:011/10/22crwdne2935283:0
657 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-2, Petersen Fall 2022 crwdns2935289:0UMass Dartmouth, Team 2-2, Petersen Fall 2022crwdne2935289:0
UMASSD-PETERSEN-F22S2G2
crwdns2947412:05crwdne2947412:0
Where do I get this battery replacement
Dallas Massey - crwdns2934203:0crwdne2934203:0
people that has purchased this product. If the battery goes dead where can someone purchase a replacement battery from and what size battery would they need
Pamela Wright - crwdns2934203:0crwdne2934203:0
Is there a P/N for the battery pack or it needs to be bought individually and then put together
Thank you
Bought a 2CR17335A-WK17 battery pack from Amazon for $15 plus tax. Just had to splice wires to existing connector to match the motherboard. So far so good. Had a 5 chirp tone every 2 minutes advising battery had come to end of life. Not sure why a 10 year battery only lasted 3 years from the manufacturing date but oh well.
Mario Garcia - crwdns2934203:0crwdne2934203:0
Bought this on Amazon. Soldered the cable from the old battery to the new one and everything works good as new :)
SHENYANG MR-BAT6V1 2CR17335A WK17 6V 1800mAh Battery with Plug for Mitsubishi CNC https://a.co/d/4PbtZJK
Johnny Sutherland - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 100
crwdns2942667:0crwdne2942667:0 2,098
