Olympus Tough TG-1 Lens Box Replacement
  1. Olympus Tough TG-1 Lens Box Replacement, Top of Camera: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The top of the camera does not contain screws. You do not need to remove anything from the top of the camera.
  2. Olympus Tough TG-1 Lens Box Replacement, Plug Side: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus Tough TG-1 Lens Box Replacement, Plug Side: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus Tough TG-1 Lens Box Replacement, Plug Side: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 5 mm screws on the side of the camera with the plug.
    • Open the compartment door and remove both 6 cm screws inside of the compartment door. This will allow you to remove the tan piece held by the screws.
  3. Olympus Tough TG-1 Lens Box Replacement, Bottom: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the camera so that you are looking at the bottom of the camera.
    • Remove the two 4 mm screws from the bottom of the camera.
    • The screws are different. The rear screw is has an unthreaded shank to locate the outer shell while screwing into the inner frame.
  4. Olympus Tough TG-1 Lens Box Replacement, Front Panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus Tough TG-1 Lens Box Replacement, Front Panel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus Tough TG-1 Lens Box Replacement, Front Panel: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tool to remove both components of the front panel. This includes the black part on the outside of the front panel and the main silver panel.
    • Once every screw and panel is removed, you can replace the backplate to make your camera weatherproof again.
  5. Olympus Tough TG-1 Lens Box Replacement, Opening the Internal Case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus Tough TG-1 Lens Box Replacement, Opening the Internal Case: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus Tough TG-1 Lens Box Replacement, Opening the Internal Case: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the plastic opening tools, carefully open the case.
    • Do not tear the white circuit ribbon.
  6. Olympus Tough TG-1 Lens Box Replacement, Opening the Screen's Protective Cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus Tough TG-1 Lens Box Replacement, Opening the Screen's Protective Cover: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus Tough TG-1 Lens Box Replacement, Opening the Screen's Protective Cover: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the screwdriver, remove the ten 3mm anchor screws.
    • Using the plastic opening tool, open the protective cover so that the screen is exposed.
  7. Olympus Tough TG-1 Lens Box Replacement, Unclipping the Screen from the Circuit Ribbon: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully unclip the screen from its circuit ribbon.
  8. Olympus Tough TG-1 Lens Box Replacement, Lens Box: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the lens box attached to the motherboard.
  9. Olympus Tough TG-1 Lens Box Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Olympus Tough TG-1 Lens Box Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Olympus Tough TG-1 Lens Box Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the copper foiled ribbon away from the lens box.
    • Detach the box by unclipping the ribbons connected to the motherboard.
    • Lift the box out of the camera.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Richard Yacobellis
crwdns2935283:001/21/15crwdne2935283:0
225 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 4-6, Brown Winter 2015 crwdns2935289:0USF Tampa, Team 4-6, Brown Winter 2015crwdne2935289:0
USFT-BROWN-W15S4G6
crwdns2942667:0crwdne2942667:0 1,651
