Is your LCD Screen cracked or unresponsive? Use this guide to replace it and get back to taking awesome photos.
We highly suggest you use a magnetic project mat or an organization tray. This camera has many different types of screws and keeping them organized is key to proper reassembly.
Turn the camera upside down.
Push the grey tab to the right to open the battery compartment.
Pull out the battery.
Use a Phillips #00 screwdriver to remove the three 2.3 mm screws from the base of the LCD screen.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the two 2.2 mm Phillips screws located on the back of the LCD screen.
Use tweezers to remove the top LCD bracket.
Use a Phillips #00 screwdriver to remove the four 1.4 mm screws from the back of the LCD screen.
Remove the LCD ribbon cable with a pair of tweezers.
Carefully lift the LCD screen up and away from the assembly.
Use tweezers to peel back the plastic cover.
Be very careful i destroyed the wrong cables in that step.
Use a spudger to flip back the black bar on the LCD Ribbon ZIF connector.
Gently pull the ribbon cable out with tweezers.
Remove the LCD Screen.
Thank you so much. Just fixed my cam!
There is more to it than shown here. You must remove the circuit board from the back of the old LCD screen, unplug those ribbon cables, transfer the circuit board to the new screen, and plug in the cables.
crwdns2947412:010crwdne2947412:0
Magnifico
Great Work!!
Where can I buy a replacement LCD screen?
You don't show the final part taking the glass away from outer and the board, as the screen replacements don't come with connector board
@josollis: Thanks for the hint! I got the missing info from the E-P5 LCD exchange instructions (on ifixit).
I have reassembled the unit after replacing the broken Ribbon, however my LCD images are inverted in normal mode not selfie mode. Do anyone know why ?
Thanks in advance
Same problem, stuck in selfie mode. Upside down display in normal mode. Hope somebody could help. Thanks!
Je rencontre le même problème d'image inversé. Pas trouvé de solution ailleurs pour le moment...
any one know where to get the hole flip mechanism for the screen?
I have a question. The back frame of the flip screen is broken as well. Where can I get replacement? Thanks!
Hi, any luck finding that part?
