Olympus FE-210 LCD Screen Replacement
crwdns2942287:0crwdne2942287:0Before removing the LCD screen you must first remove the rear camera casing.
crwdns2944105:0crwdne2944105:0
The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
Remove the 7 screws holding the front case in place, with a #00 screwdriver.
Six screws are 3.6 mm.
The seventh screw is 3.2 mm.
Pulling the front case off, requires applying enough strength in the right areas.
The front case snaps into place in three places:
At the top and bottom of the battery side (opposite of side pictured) of the case.
Right in the middle of the DC-in side (side pictured) of the case.
Top of the camera, to the left of the power button.
Once those places are disconnected, the front case will pop right off.
Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard.
Lift the white latch using a fingernail or a spudger.
Pull the cord from its connector.
Remove the two 2.7 mm screws using a #00 screwdriver.
Using a spudger, lift the latch on the connector.
Remove the ribbon cord from its connector.
Remove the LCD from the rest of the camera.
Now need source for replacement screen thank you
