OP-1 Key/button Removal and Cleaning Guide
Brian Fox
crwdns2944107:0crwdnd2944107:0Brian Foxcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:04crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Maw 17, 2019crwdne2944111:0
crwdns2931287:030crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2944444:0crwdne2944444:0
crwdns2942287:0crwdne2942287:0
The Op-1 is a killer synthesizer, but suffers from many problems all other synthesizers do. Here we are gonna find out how to take off all the keys/buttons to either clean the key bed or access the other assemblies below. Please remember that performing any work on the op-1 voids its warranty therefore should only be done with extreme caution. Not following this procedure properly can damage its parts or destroy the unit forever. Please wear protective eyewear.
  1. OP-1 Key/button Removal and Cleaning Guide, OP-1 Key/button Removal and Cleaning Guide: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 OP-1 Key/button Removal and Cleaning Guide, OP-1 Key/button Removal and Cleaning Guide: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 OP-1 Key/button Removal and Cleaning Guide, OP-1 Key/button Removal and Cleaning Guide: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First and foremost. These keys on the OP-1 are delicate, but not cheap. Be careful with them, but do not be afraid to use a little force to remove them.
    • Next we have to make a proper tool to make removing them safe and easy
    • I tried a few different versions, the first ones being plastic and nothing succeeded as well as a classic metal spudger with a slight modification
    • Simply bend the triangular tip in about 75 degrees. This will help get underneath the keys to release the tabs.
    You should definitely heat this with a blowtorch before attempting to bend. I tried bending the pointy side first and it snapped right off. Used a blowtorch for the other rounded side and was able to get a proper bend.
    jmm.seasons - crwdns2934203:0crwdne2934203:0
  2. OP-1 Key/button Removal and Cleaning Guide: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OP-1 Key/button Removal and Cleaning Guide: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • I found it best to start by removing the keys starting at the bottom left
    • The first 3 square keys on the bottom will be the hardest to remove. Once you remove them, access to the others will be easier.
    • To access them you must insert the modified tool in the gap between the key and the aluminum case.
    • You then must get the tip of the tool above the key tabs and the key scissor clips that hold it on.
    • The clips that hold the key are circled in orange. Pull the key back in the direction of the red arrows and slide the key off those back guide tabs. Please look at the next step for video examples of how to remove the keys BEFORE trying to remove them.
    • One swift gentle but firm motion...:)
    • Heres another example. Feel free to look ahead to see a closer look at what the key assembly looks like removed.
  3. OP-1 Key/button Removal and Cleaning Guide: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OP-1 Key/button Removal and Cleaning Guide: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The red area is the back of the key and the orange tabs are where the key connects into the previously labeled orange scissor clips.
  4. OP-1 Key/button Removal and Cleaning Guide: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OP-1 Key/button Removal and Cleaning Guide: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pictured here is a piano key, but it has the same connection from the key to the scissor clip as the rest
    • The best solution is to insert the modified spudger below the inside of the key and above the key scissor clip right where the red arrow points (do not insert the tool where the dental pick is here)
    • Then pull downward to release the clip from the tabs labeled with the orange arrows.
  5. OP-1 Key/button Removal and Cleaning Guide: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 OP-1 Key/button Removal and Cleaning Guide: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Removing the rest from here is pretty straight forward except for one part. The black piano keys alternate tab removal access points. They are labeled for your enjoyment
  6. OP-1 Key/button Removal and Cleaning Guide: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 OP-1 Key/button Removal and Cleaning Guide: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 OP-1 Key/button Removal and Cleaning Guide: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Start from the left and work your way right.
    • Once again make sure you note the correct insertion point
    • Also note that sometimes the scissor clip occasionally detaches from the key bed, but don't fret they easily reinsert.
    Hey, it would be very helpful to include instructions on how to reinsert keys. I think I can figure it out, but it’s taking some time/work. Thanks!
    daniel ryan - crwdns2934203:0crwdne2934203:0
crwdns2935229:09crwdne2935229:0
Brian Fox
crwdns2935283:010/16/13crwdne2935283:0
1,709 crwdns2915208:0crwdne2915208:0
crwdns2947412:013crwdne2947412:0
A very useful article. Does anyone know if the key caps are available elsewhere?
Dave Meadows - crwdns2934203:0crwdne2934203:0
Hello, is it possible to order the scissor clips for the black key on the far right of my OP-1?
Thanks,
Patrick
Patrick T Gill - crwdns2934203:0crwdne2934203:0
Patrick - read the below. x
Nano Visuals -
Not really. I contacted TE about my snapped plastic scissor bracket replacement. The guy from customer service asked me to put on hold as they were out of stock. After 4 months waiting time I got an email to spent 80 quid and get a whole keyboard panel. I asked why and it makes no sense, also that does not seem to be too eco-friendly either. I had to wait aprox 5-6 weeks for a reply. Hows that TE ?
Nano Visuals - crwdns2934203:0crwdne2934203:0
Im going to 3D print it so suck on that TE. Thanks x
Hey you think you’d be able to 3D print another scissor clip for an A#?
Ermahderg -
hey brian, thanx a lot for your tutorial. i ve problems with 2 key. they are not ever working. i think, is in cause of sweat driped on it. it possible to clean the contacts? thanx. ingo, berlin.
ingo-gue - crwdns2934203:0crwdne2934203:0
Is it possible to get 1 key that broke off ? So much money for such a flimsy piece of hardware
Jango Alchemist - crwdns2934203:0crwdne2934203:0
A guy from Berlin, Germany is (still) selling individual keys : https://www.ebay-kleinanzeigen.de/s-anze...
Luka Ivanovic - crwdns2934203:0crwdne2934203:0
Thanks for this. However, I don’t see any cleaning instructions. May I ask how to go about cleaning the contacts underneath the rubber membrane? My OP-1 has issues with intermittent key responsiveness and double-triggering of notes.
ToFu - crwdns2934203:0crwdne2934203:0
I would love to know if you made any progress on that one. My T3 key is barely responsive anymore…
Sébastien Barré -
Thanks for excellent tutorial. I need the new keybed as there is a dead key. I took the keyboard off, cleaned, reconnected ribbons to no avail. Sadly iFixit North America is out of stock, and the other stores will not ship to NA. Will wait until they come back in stock.
Eric Larsen - crwdns2934203:0crwdne2934203:0
I bought a new OP-1 and after the first sound check I found an extremely sensitive piano key.
Thanks to this article and this lifehack https://www.reddit.com/r/OP1users/commen... with a piece of 6x7mm paper, I managed to fix the problem in 20 minutes. I hope this helps those who have a similar problem.
nik-boy96 - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 42
crwdns2936753:030crwdne2936753:0 134
crwdns2942667:0crwdne2942667:0 23,848
