crwdns2933315:07crwdne2933315:0
crwdns2934263:01crwdne2934263:0
crwdns2934263:05crwdne2934263:0
Background and Identification
The OP-1 is a portable music workstation incorporating a synthesizer, sampler, sequencer, multitrack recorder, drum machine, mixer, and controller made by Teenage Engineering, a Swedish consumer electronics company founded in 2005. The OP-1 was released in 2011 as Teenage Engineering’s first product and is considered the company’s core product.
The OP-1 is known for its untraditional design, AMOLED display, and the depth of its eleven synthesis engines. The synthesizer combines multiple synthesizer engines, sampler, four sequencer types, a tape-style 4-track recorder, a motion sensor, and an FM radio. The OP-1 has received some criticism for its physical limitations, but Teenage Engineering has said these limitations encourage user creativity. Teenage Engineering introduced several accessories for the OP-1 in 2012 that can be used to manipulate the OP-1’s macro effect knobs. The price of the OP-1 increased by about 35% in 2019 to cover new parts and redesigned hardware.
The OP-1 features a 320 by 160-pixel OLED (organic light-emitting diode) screen, which displays a graphical representation of the synthesizer’s current mode. The device includes a fixed-velocity keyboard with 24 keys. Arrow keys can be used to move up or down entire octaves while in drum or synthesizer mode, and the device has a range of eight octaves total.
The OP-1 includes the model name “OP-1” in the lower right-hand corner of the device, printed vertically in capital letters.
Technical Specifications
Input/Output:
  • USB: 2.0 high-speed (OTG)
  • Line In/Out: 3.5mm jack
  • Microphone: Built-in
  • Speaker: Mini: High output, 8 Ω, 1 W
  • Motion Sensor: 3-axis accelerometer (G-force); Assignable to any synth, envelope, effect parameter, or to pitch
  • Radio: FM Band Support: Worldwide (64 to 108 MHz)
Display:
  • Type: AMOLED display running in 60 fps
  • Resolution: 320 x 160p
  • Color Depth: 16.7 million
  • Contrast: 10,000:1 (good for outdoor use)
  • Viewing Angle: 170°
  • Lifetime: 30,000 hours
Mechanical:
  • Design:
    • Low-profile keyboard module
    • Scissor-switch ultra-low-profile design
    • Expected lifespan of 10 million keystrokes per key
Encoder:
  • Type: Industrial-grade incremental encoders
  • Life
    • Rotational: Up to 1,000,000 revolutions
    • Good indexing feel (remains consistent over life)
  • Material: Zinc die-cast and fiber-enforced, high-performance plastic (used in Avionics)
Battery:
  • Battery Type: Li-ion 1,800 mAh
  • Battery Life: 16 hours (active)
  • Charging: Via USB port
General:
  • CPU:
    • 400MHz core processor (800 MMACSS performance)
    • 64MB low-power SDRAM (12ns)
    • 512MB NAND flash storage
    • 24-bit 96kHz ADC/DAC
  • Body:
    • Advanced CNC 1-piece aluminum design
    • 2 x M6 Mounting holes for accessories
    • 2 x Cuts for strap accessory
  • Operating Temperature Range-40 to 185°F (-40 to 85°C)
  • Dimensions (LxHxD): 11.1 x 4.0 x 0.5" (282.0 x 102.0 x 13.5mm)
Additional Information
teenage engineering
crwdns2935283:010/23/13crwdne2935283:0
1,131 crwdns2915208:0crwdne2915208:0
Teenage Engineering crwdns2935289:0Teenage Engineeringcrwdne2935289:0
Community
crwdns2936751:024crwdne2936751:0 28
crwdns2936753:07crwdne2936753:0 158
crwdns2936753:030crwdne2936753:0 474
crwdns2959996:0crwdne2959996:0 84,478
