Nvidia Shield Battery Assembly Replacement
Andrew Barbanera
crwdns2944107:0crwdnd2944107:0Andrew Barbaneracrwdnd2944107:0crwdnd2944107:0crwdnd2944107:08crwdnd2944107:0crwdne2944107:0
crwdns2944111:0January 22, 2024crwdne2944111:0
crwdns2931287:010crwdne2931287:0
crwdns2937799:0crwdne2937799:0
crwdns2942287:0crwdne2942287:0
This will be a step-by-step guide to remove the battery assembly from the Nvidia Shield. This will need to be performed to install a new battery into the device. The user will not need any special skills beforehand to successfully remove the battery. The user can put the device back together with a new battery installed by following the steps in reverse. Replacing the battery in a Nvidia Shield can help improve the quality of the battery life of the product. If you notice the battery swelling or smoking, before proceeding check out the guide for what to do with a swollen battery.
  • T5 Torx Screwdriver
    T5 Torx Screwdriver
  • Spudger
    Spudger
crwdns2944105:0crwdne2944105:0
  1. Nvidia Shield Battery Assembly Replacement, Remove Front Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nvidia Shield Battery Assembly Replacement, Remove Front Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nvidia Shield Battery Assembly Replacement, Remove Front Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
    For the rubber screw covers, it is easiest to push at them at the top, otherwise you have the possibility of damaging the surrounding rubber.
    Any hints at getting the center plastic screw cover out?
    Miles Raymond - crwdns2934203:0crwdne2934203:0
  2. Nvidia Shield Battery Assembly Replacement, Remove Green Grill: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nvidia Shield Battery Assembly Replacement, Remove Green Grill: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nvidia Shield Battery Assembly Replacement, Remove Battery Cables: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Battery Assembly Replacement, Remove Battery Apparatus: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery apparatus out once all cables are removed.
crwdns2935229:05crwdne2935229:0
Andrew Barbanera
crwdns2935283:009/20/14crwdne2935283:0
376 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-1, Hickman Fall 2014 crwdns2935289:0USF Tampa, Team 1-1, Hickman Fall 2014crwdne2935289:0
USFT-HICKMAN-F14S1G1
crwdns2935297:018crwdne2935297:0
For replacement batteries, are they 18650? Do I want flat top or button tops?
evan - crwdns2934203:0crwdne2934203:0
Hello,
any idea what connector the battery uses? I have a replacement pack but they put the cable on the wrong side of the pack (doesn’t fit backwards either)
Brett - crwdns2934203:0crwdne2934203:0
The original cells are rated for 3.7v, 2450mAh, and I don't know how many amps but it's probably not that many. The form factor is flat-top 18650. I successfully did this repair using 3 Samsung 35E cells: https://www.18650batterystore.com/produc...
Charles Hall - crwdns2934203:0crwdne2934203:0
So, is this battery pack compatible? I read it has the connector in the wrong side
andres.430 - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 56
crwdns2942667:0crwdne2942667:0 6,621
