This repair may take some time because you have to remove everything in the device in order to access the screen and adhesive is used to keep the screen attached to its frame.
Use a Heat Gun to heat the sides of the device and loosen the adhesive.
Pry up the the back of the device.
Follow the instructions for the following replacement guides to get under the touch screen: Camera Replacement; Headphone Jack; Charging Port; and Battery Replacement.
Slowly pull the speaker out of its bed.
If you have not done so already, de-solder the boards from the device.
The touch screen should lift right out of the device.
Use the Heat Gun to heat the adhesive between the screen and edge protector.
Pry the two pieces apart.
