NuVision Duo 11 Motherboard Replacement
  1. NuVision Duo 11 Motherboard Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the flat end of a nylon spudger in the gap between the cover and the rest of the device.
    • Slide the spudger down each side until you hear numerous clicks.
    • Remove the back panel from the tablet.
  2. NuVision Duo 11 Motherboard Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NuVision Duo 11 Motherboard Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove any pieces of electrical tape that may be adhered to the battery.
    • The tape may be adhered to wires; be sure to pull up the tape slowly.
  3. NuVision Duo 11 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  4. NuVision Duo 11 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently peel the battery from the front case.
    • You will be met with some resistance, so it is critical that you are very careful.
    • DO NOT puncture or bend the battery. It may explode or leak toxic chemicals.
  5. NuVision Duo 11 Motherboard Replacement, Speakers: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NuVision Duo 11 Motherboard Replacement, Speakers: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  6. NuVision Duo 11 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the speakers from the casing using a nylon spudger.
    • The speakers may be glued down, so use caution when prying them out.
  7. NuVision Duo 11 Motherboard Replacement, Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 NuVision Duo 11 Motherboard Replacement, Motherboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect each ribbon cable from their respective clips on the motherboard.
  8. NuVision Duo 11 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 4.8 mm screws from the motherboard using a JIS #000 screwdriver.
  9. NuVision Duo 11 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard from the tablet.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Gavin Amaral
crwdns2935283:003/16/23crwdne2935283:0
377 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 7-1, Ryckebusch Spring 2023 crwdns2935289:0UMass Dartmouth, Team 7-1, Ryckebusch Spring 2023crwdne2935289:0
UMASSD-RYCKEBUSCH-S23S7G1
crwdns2942667:0crwdne2942667:0 243
