Nostalgia Electrics PCM805 Heating Element
  1. Nostalgia Electrics PCM805 Heating Element, Bowl: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure that the device is unplugged and has not been used recently because the extractor head and bowl can be very hot.
    • Place the device on a steady table.
    • Lift and remove the rim.
  2. Nostalgia Electrics PCM805 Heating Element: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nostalgia Electrics PCM805 Heating Element: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nostalgia Electrics PCM805 Heating Element: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Twist the bowl clockwise until it is free of the groove and lift to remove.
  3. Nostalgia Electrics PCM805 Heating Element, Extractor Head: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nostalgia Electrics PCM805 Heating Element, Extractor Head: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly grip the extractor head and slowly lift vertically to remove from the device.
  4. Nostalgia Electrics PCM805 Heating Element, Unscrewing the base: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nostalgia Electrics PCM805 Heating Element, Unscrewing the base: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the device before following this guide.
    • First, place the device on its side, making sure the switch is not facing down.
    • Remove the eight 12mm Phillips #02 screws from the base.
  5. Nostalgia Electrics PCM805 Heating Element: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently separate the panel from the device.
    • Be sure not to tug at the wires that are still connected.
  6. Nostalgia Electrics PCM805 Heating Element, Nostalgia Electrics PCM805 Wiring Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nostalgia Electrics PCM805 Heating Element, Nostalgia Electrics PCM805 Wiring Teardown: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the tie strap holding the wires and cut with a pair of scissors.
    • Use care not to snip the wires.
  7. Nostalgia Electrics PCM805 Heating Element: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nostalgia Electrics PCM805 Heating Element: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nostalgia Electrics PCM805 Heating Element: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make note of the wiring arrangement of each bundle before this step.
    • Using wire cutters, cut each wire as close to the wire connector as possible.
    • Cut the wires in both bundles.
    • To reassemble the cotton candy maker after cutting the wires, follow our rewiring guide.
  8. Nostalgia Electrics PCM805 Heating Element, Heating Element: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nostalgia Electrics PCM805 Heating Element, Heating Element: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six 10mm Phillips #02 screws that secure the metal housing covering the heating element.
    • Remove the metal housing.
  9. Nostalgia Electrics PCM805 Heating Element: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nostalgia Electrics PCM805 Heating Element: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 9mm Phillips #02 screws that secure the heating element to the rest of the device.
  10. Nostalgia Electrics PCM805 Heating Element: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nostalgia Electrics PCM805 Heating Element: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Line up the prongs on the motor shaft with the slots in either side of the hole in the heating element and lift it off the device.
Nicholas Fazio
crwdns2935283:001/13/15crwdne2935283:0
194 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 3-5, Hickman Winter 2015 crwdns2935289:0USF Tampa, Team 3-5, Hickman Winter 2015crwdne2935289:0
USFT-HICKMAN-W15S3G5
Where can I buy a replacement heating element?
Eric P. Rose - crwdns2934203:0crwdne2934203:0
For the heating element, the grate popped off. What silicone is used to keep the parts together? Same for the springs inside the white tubes.
Jenilee Brown - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,890
