crwdns2959928:0crwdne2959928:0 ↓Use this guide to replace your heating element if it has stopped working.
Utility Scissors4.9
Place the device on a steady table.
Lift and remove the rim.
Twist the bowl clockwise until it is free of the groove and lift to remove.
Firmly grip the extractor head and slowly lift vertically to remove from the device.
First, place the device on its side, making sure the switch is not facing down.
Remove the eight 12mm Phillips #02 screws from the base.
Gently separate the panel from the device.
Locate the tie strap holding the wires and cut with a pair of scissors.
Using wire cutters, cut each wire as close to the wire connector as possible.
Cut the wires in both bundles.
Remove the six 10mm Phillips #02 screws that secure the metal housing covering the heating element.
Remove the metal housing.
Remove the four 9mm Phillips #02 screws that secure the heating element to the rest of the device.
Line up the prongs on the motor shaft with the slots in either side of the hole in the heating element and lift it off the device.
Where can I buy a replacement heating element?
Eric P. Rose - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
For the heating element, the grate popped off. What silicone is used to keep the parts together? Same for the springs inside the white tubes.
Jenilee Brown - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
