Nook BNRV300 Display Replacement
  1. Nook BNRV300 Display Replacement, Power Button: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nook BNRV300 Display Replacement, Power Button: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nook BNRV300 Display Replacement, Power Button: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Power off your Nook before working on your device. Hold the power button for about 5 seconds and select the “Power Off” option.
    • Turn the Nook over to find the power button along the back upper edge.
    • Wedge the spudger between the top of the power button and the upper edge of the device.
    • Push the tool down to pry the button up and off.
    You should pull up from the bottom of the button. It will hing up and pop off easier and less chance of breaking the button. There is a hing on the top side of the button to pivot down to the bottom where the button is. The clips are near the bottom of the button. You are more likely to break the pivot pins doing it from the top.
    dl200010 - crwdns2934203:0crwdne2934203:0
  2. Nook BNRV300 Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, take off the power button.
  3. Nook BNRV300 Display Replacement, Back Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nook BNRV300 Display Replacement, Back Cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nook BNRV300 Display Replacement, Back Cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel off the white sticker that is covering the screw head.
    • Remove the one 2mm-long screw using a size T5 Torx screwdriver.
  4. Nook BNRV300 Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the back cover down towards the USB port to release it. The pictures show the case being pried open but this should not be necessary.
    There is no need to pry the cover off. Just slide the back cover down toward the USB port.
    Young - crwdns2934203:0crwdne2934203:0
    This right here! It requires little to no force to do this. You are more likely to break the clips if you force it open.
    dl200010 -
    Oh man, this is absolutely right! Sliding it down away from the power button is so easy. I'm sad I didn't see this comment until after I had pried it off. I couldn't figure out how to put it back on after changing the battery, but sliding it back up is easy. iFixit should definitely update the instructions to clarify this.
    Dirk Padfield -
    Looks like they updated the instructions! Although they said “prised” instead of pried. :(
    Jonathan P - crwdns2934203:0crwdne2934203:0
  5. Nook BNRV300 Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nook BNRV300 Display Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nook BNRV300 Display Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger or your fingers to gently pry the connector out of the white socket.
    • The back cover is now fully detached.
  6. Nook BNRV300 Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nook BNRV300 Display Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to remove the brass-colored threaded fastener from the Nook plastic casing.
    There’s absolutely no reason to do this. This part of the device is never touched again for the rest of the guide.
    James Beegle - crwdns2934203:0crwdne2934203:0
  7. Nook BNRV300 Display Replacement, Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nook BNRV300 Display Replacement, Motherboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an anti-static mat to prevent electric shock from damaging the motherboard and its components. Be careful when using metal tools on your device.
    • Using a T5 Torx screwdriver, remove the eleven 3mm screws.
  8. Nook BNRV300 Display Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nook BNRV300 Display Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nook BNRV300 Display Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the spudger through the loop of the display cable. Lift the tool up, which will unhook the display cable.
    • Do not put force on the motherboard with the spudger. This could damage components on the motherboard.
    • Using your fingers, lift up the display cable.
  9. Nook BNRV300 Display Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, gently lift the motherboard from the display.
  10. Nook BNRV300 Display Replacement, Display: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nook BNRV300 Display Replacement, Display: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nook BNRV300 Display Replacement, Display: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a nylon spudger between the display's metal backing and the front cover plastic.
    • Gently pry the display away from the front cover by moving the spudger up and down.
    • During reassembly, align the small black plastic peg at the bottom right of the plastic frame with the inner hole at the bottom right of the metal display backing.
  11. Nook BNRV300 Display Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nook BNRV300 Display Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press down on the fastener tab with your finger.
  12. Nook BNRV300 Display Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nook BNRV300 Display Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The display cracks very easily. If this happens, there will be glass shards that could potentially cause injury. You may want to wear protection for hands and eyes while completing this step.
    • Insert a nylon spudger between the plastic frame on the display and the metal casing on the display.
    • Gently pry the display away from the plastic frame. Place the display on a hard, flat surface to support it when prying it off the metal backing. The screen may crack anyway.
Alisyn Waite
crwdns2935283:010/03/19crwdne2935283:0
402 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S1-G1, Al-Hmeyrat Fall 2019 crwdns2935289:0Eastern Washington University, Team S1-G1, Al-Hmeyrat Fall 2019crwdne2935289:0
EWU-AL-HMEYRAT-F19S1G1
crwdns2947412:05crwdne2947412:0
Was all good till I got here:
The display was glued to the metal backing. Needs something to heat up the adhesive in order to remove it.
Joseph W Charpentier - crwdns2934203:0crwdne2934203:0
Hi. What display model should I look for? Is this one ED060SC7 good?
pogo79 - crwdns2934203:0crwdne2934203:0
I'm looking in the Aliexp... store and I don't know what display to choose .
Check the comments on each step. There are some adjustments to the process to properly and safely take this apart.
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 2,809
