Nook BNRV300 Battery Replacement
  1. Nook BNRV300 Battery Replacement, Power Button: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nook BNRV300 Battery Replacement, Power Button: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nook BNRV300 Battery Replacement, Power Button: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Power off your Nook before working on your device. Hold the power button for about 5 seconds and select the “Power Off” option.
    • Turn the Nook over to find the power button along the back upper edge.
    • Wedge the spudger between the top of the power button and the upper edge of the device.
    • Push the tool down to pry the button up and off.
  2. Nook BNRV300 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, take off the power button.
  3. Nook BNRV300 Battery Replacement, Back Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nook BNRV300 Battery Replacement, Back Cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nook BNRV300 Battery Replacement, Back Cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel off the white sticker that is covering the screw head.
    • Remove the one 2mm-long screw using a size T5 Torx screwdriver.
  4. Nook BNRV300 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the back cover down towards the USB port to release it. The pictures show the case being pried open but this should not be necessary.
  5. Nook BNRV300 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nook BNRV300 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nook BNRV300 Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger or your fingers to gently pry the connector out of the white socket.
    • The back cover is now fully detached.
  6. Nook BNRV300 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nook BNRV300 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to remove the brass-colored threaded fastener from the Nook plastic casing.
  7. Nook BNRV300 Battery Replacement, Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nook BNRV300 Battery Replacement, Battery: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nook BNRV300 Battery Replacement, Battery: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The battery is located on the inside back cover of the Nook.
    • Do not use metal tools when prying up the battery. This may puncture the battery and cause harm to you and/or your device.
    • Insert a nylon spudger beneath the clear plastic adhesive holding the battery to the back cover.
    • Work around the battery, peeling up all of the adhesive.
  8. Nook BNRV300 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nook BNRV300 Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold on to one of the adhesive tabs and pull up.
    • This will fully remove the battery from its compartment.
crwdns2935229:05crwdne2935229:0
Emily Tracy
crwdns2935283:010/03/19crwdne2935283:0
425 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S1-G1, Al-Hmeyrat Fall 2019 crwdns2935289:0Eastern Washington University, Team S1-G1, Al-Hmeyrat Fall 2019crwdne2935289:0
EWU-AL-HMEYRAT-F19S1G1
Check the comments on each step. There are some adjustments to the process to properly and safely take this apart.
dl200010 - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 63
crwdns2942667:0crwdne2942667:0 4,179
