Nokia XL Dual SIM Motherboard Replacement
  1. Nokia XL Dual SIM Motherboard Replacement, Back Cover Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You will first need to separate the back cover from the device.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
  2. Nokia XL Dual SIM Motherboard Replacement, Battery Removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia XL Dual SIM Motherboard Replacement, Battery Removal: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back cover.
    • Use a plastic opening tool to lift the battery. Then, remove it.
  3. Nokia XL Dual SIM Motherboard Replacement, Screen Separation part 1: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia XL Dual SIM Motherboard Replacement, Screen Separation part 1: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
    • You will need a T5 Precision Torx screw driver to remove the screws.
    • The locations of the T5x3.4mm screws are indicated in the picture.
    • The locations of the T5x4.1mm screws are indicated in the picture.
  4. Nokia XL Dual SIM Motherboard Replacement, Screen Separation part 2: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia XL Dual SIM Motherboard Replacement, Screen Separation part 2: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia XL Dual SIM Motherboard Replacement, Screen Separation part 2: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tool to gently pry the device apart.
    • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
    • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
  5. Nokia XL Dual SIM Motherboard Replacement, System components: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the device is open, take note of all the components.
  6. Nokia XL Dual SIM Motherboard Replacement, Removing Connectors: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia XL Dual SIM Motherboard Replacement, Removing Connectors: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With tweezers, gently unsnap the motherboard connectors for all components.
    • The location of all the connectors is indicated in the next step.
    The lighting could be better for the images in both of these steps.
    Dan Brown - crwdns2934203:0crwdne2934203:0
  7. Nokia XL Dual SIM Motherboard Replacement, Connector Locations: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia XL Dual SIM Motherboard Replacement, Connector Locations: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia XL Dual SIM Motherboard Replacement, Connector Locations: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The 3 motherboard connectors for the touchscreen, volume buttons, and power/screen lock button assembly are indicated on the picture.
    • The touchscreen assembly can now be removed and set aside.
    • The motherboard connector for the front camera is indicated on the picture.
    • The motherboard connector for the camera flash, vibrator, and headphone jack assembly is indicated in the picture.
  8. Nokia XL Dual SIM Motherboard Replacement, Remove motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia XL Dual SIM Motherboard Replacement, Remove motherboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pry up on the top underside of the motherboard with the small plastic opening tool.
    • Gently pulling upward on the motherboard will allow it to be removed.
crwdns2935229:08crwdne2935229:0
Christopher Weaver
crwdns2935283:009/25/14crwdne2935283:0
984 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-4, Brown Fall 2014 crwdns2935289:0USF Tampa, Team 1-4, Brown Fall 2014crwdne2935289:0
USFT-BROWN-F14S1G4
I removed my charging system while removing the charger from the phone after that i sgave it to phone repaire to insert a new charging system ,When my phone was ready he gave it to me,After i switched it on it turned bluish incolour the whole screen,so what can i do pls?
jmwachofi8 - crwdns2934203:0crwdne2934203:0
My phone is not charging when I plug it on the wall you ll see the charging indication on the battle sign on the phone that it is charging but it won't from morning to the next day it ll not what should i do,please
John - crwdns2934203:0crwdne2934203:0
My nokia xL was plugged in a big battery of Inverter and was switched off and after that it stops working
Sahil ali - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 8,372
